Is this normal???
Old Jun 22, 2004 | 09:47 AM
nissanfreak's Avatar
Is this normal???
I have a 99 Maxima SE-Limited. Everytime I start up my car the oil light says on for about a second or two then it turns off. Is that normal? Could it be that my oil level is low? Thanks in advance
Old Jun 22, 2004 | 09:52 AM
NmexMAX's Avatar
dot dot dot ...
Its not oil level, its oil PRESSURE, and it may blink once or twice when you first start up because pressure may be slightly low at startup. Nothing to worry about.
Old Jun 22, 2004 | 10:02 AM
thanks for the quick reply NmexMAX! I was starting to get worried thinking that maybe its my oil pump or something like that. Thanks again I feel better now
Old Jun 22, 2004 | 10:07 AM
Iqb316's Avatar
Mine does the same thing, no problems here! If the light would continue to stay on after start-up, then you'd have something to worry about!
Old Jun 23, 2004 | 06:33 PM
Wills98MaxSE's Avatar
1 of few unmodded 4G Maxs
everything is fine, the oil light comes on as a test during startup and should normally go away in a second or so
Also I'd worry about the following w/ the oil light -
1) staying on after startup
2) not coming on at all, even at startup (bad bulb)
Old Jun 23, 2004 | 06:44 PM
95stillenmax's Avatar
mine does it to dont worry
Old Jun 24, 2004 | 05:14 AM
NmexMAX's Avatar
dot dot dot ...
I think he gets the point. . .
user 11122324
42
Jul 18, 2022 03:35 PM
Miket2006
Mar 1, 2021 03:55 AM
RWCreative
Sep 21, 2015 11:01 AM
NissanNismoZ
Sep 12, 2015 07:30 AM
