Life expectancy of O2 sensors & can they cause hesitation?
Old Jun 22, 2004 | 06:16 PM
Wills98MaxSE's Avatar
1 of few unmodded 4G Maxs
Just wondering what the average lifespan of the O2 sensors are on our Max's and if they're worn, can they cause hesitiation problems?
I have over 105K on my '98 SE and recently did tune up (filters, plugs, etc) and a BG Fuel Induction service (tb & fuel system cleaned out), yet still experiencing some hesitation and was wondering w/ the amount of miles on my max, would it be time to change all the O2 sensors?
Old Jun 22, 2004 | 06:27 PM
95stillenmax's Avatar
maybe it is your knock sensor
Old Jun 22, 2004 | 09:24 PM
THT's Avatar
THT
Throbbing member
yes, a faulty O2 sensor will cause hesitation. When my left bank sensor went out, my car would hesitate whenever I gave it gas. I ended up changing all of my O2s within 3,000 miles of one another and the first went at about 60K.
~THT
Old Jun 23, 2004 | 08:36 AM
DonSupreme's Avatar
Wouldn't a bad o2 sensor throw a code?
Old Jun 23, 2004 | 09:12 AM
killcrap's Avatar
I'm actually quite pleasant until I'm awake
my cel came on after i changes my injectors, and i reset the ecu, and it hasnt came back since.!!
Old Jun 23, 2004 | 07:38 PM
THT's Avatar
THT
Throbbing member
Yes, a faulty O2 would trip a CEL/SES.
~THT
Old Jun 23, 2004 | 08:08 PM
Jatan's Avatar
A bad O2 sensor will turn on the CEL, but a dying one won't until it's completely dead (it'll be "slow" at sending info to the ECU)
O2s get worn out at 80k and maybe up to 100k then they become "slow" but they still have life in them. Since they're worn out, you'll see bad gas mileage (100k miles is A LOT).
I'm at 107500 miles right now and I'm planning on replacing them soon and I'm planning on getting a y-pipe soon too since my MPG isn't so great
Old Jun 23, 2004 | 08:12 PM
Maximized Jiggs's Avatar
~THT
Hey, I had the code 0303 and it pointed to that o2 sensor. Can you tell me what you did to replace it and where did you get the part?
Old Jun 23, 2004 | 08:14 PM
THT's Avatar
THT
Throbbing member
I wrote the How-to on replacing O2s in 4th gens; it's in the sticky. You can buy the part at www.oxygensensors.com
~THT
Old Jun 23, 2004 | 08:16 PM
Jatan's Avatar
There is a group deal (check the group deal section) on 15% off oxygensensors.com prices so it'll be even cheaper
Old Jun 24, 2004 | 08:48 AM
update, went to autozone yesterday b/c the SES light was on and the diag. tool showed a P0153 code for O2 sensor slow response, bank 2, sensor 1 so looks like its time for a new O2 sensor, also tripped the infamous 0304 KS code, would I be better off replacing just the bad O2 sensor or is it a good idea to replace all of them w/ over 105,500 miles?
Old Jun 24, 2004 | 05:49 PM
THT's Avatar
THT
Throbbing member
Replace just the O2, reset the ECU and see if there's a ghost code for the KS. From what I've experienced and seen, the KS code comes up when the O2s go out. However, at your mileage, I wouldn't be surprised if the KS needed replacing but why do the extra work if you don't have to?
~THT
Old Jun 25, 2004 | 06:30 PM
this might sound a little dumb to ask but just to make sure, bank 2 is the rear of the engine, correct?
THT thanx. 4 the info, I will look around to see who can fix this inexpensively, I don't have or know of my own mechanic at this time
Old Jun 25, 2004 | 11:13 PM
THT's Avatar
THT
Throbbing member
Yeah, bank 2 is toward the cabin of the car.
~THT
Old Jun 25, 2004 | 11:44 PM
Prophecy1's Avatar
Wait isint Bank 1 and 2 by the manafold and the third is right infront of the cat?
oxygensensors.com has a picture of the underneath and location. I was under the car looking at mine could swear that was the setup.
Proph
Old Jun 26, 2004 | 06:15 AM
THT's Avatar
THT
Throbbing member
Left bank is toward the front of the car. Right bank is toward the middle of the car. These two are the upstream sensors. The downstream sensor is the one in the cat.
~THT
Old Jun 26, 2004 | 08:35 AM
DAVE Sz's Avatar
Hooooooonda.....
We have 3 banks? Holy crap, I didn't know we had a v9. No dude, the rear bank is by the firewall and the front is by the rad.
Old Jun 26, 2004 | 09:13 AM
killcrap's Avatar
left is front of car, right is rear. and then there should be a sensor in your cat or b-pipe depending on your year. left and right banks use the same o2 sensors.
Old Jun 26, 2004 | 09:51 AM
waveridr85's Avatar
dont have someone do it, Get under the car and do it yourself. Its a really easy task.
Unclejunebug
Apr 2, 2016 05:42 AM
hayne
Oct 5, 2015 11:53 AM
HerpDerp1919
Sep 29, 2015 02:02 PM
zmcneely13
Sep 26, 2015 02:26 PM
