Need Help With HID's and High Beams
Old Jun 28, 2004 | 05:07 AM
EteRnity059's Avatar
Boosted?....
Hi Guys,
I currently have my projectors wired with an audi h7 harness. I have another audi h7 harness wired for a separate high beam h7 bulb.
My problem is when i flip on my high beams, the low beams cut off.
I wanted to know if there is a way to wire the low beams to work consecutively witht he high beams.
I think I've seen something on the org before.
Please help
Old Jun 28, 2004 | 06:53 AM
ManualMaxima's Avatar
5th Gen till she dies!
run a wire from the highbeam positive wire to the low beam positive.
Old Jun 28, 2004 | 07:29 AM
nupe500's Avatar
Jedi Knight
don't just run a wire...put a diode in there a 1N5404 diode, but bsaically that is what you do...so your diode & wire will run to the positive of your projector so, that it gets constant power
Old Jun 28, 2004 | 08:30 AM
yea but can't he just ran a wire before the ballast? cause teh ballast will give it ,it's constant power?
Old Jun 28, 2004 | 08:38 AM
nupe500's Avatar
Jedi Knight
He willl need to wire it before the ballast, connecting the low beam signal coming from the stalk to the high-beam one using the diode. Diode prevents any damage to the stalk and oem wiring..
jmlee44
Oct 2, 2022 02:13 PM
Apr 16, 2020 05:15 AM
maxinout93
Oct 31, 2015 02:04 AM
