Solenoid help
Old Jun 29, 2004 | 07:53 PM
sanjosemaxima's Avatar
Sleeps with his maxima!
Solenoid help
When getting a solenoid for the mevi, whats best one to get? The gm, dawes, pulsar... or is their another one that is know to be better now? thanks a lot!
Old Jun 29, 2004 | 07:58 PM
oh, also Ive heard about not putting the relays on? I dont know much about electronics, abd I was hoping somebody would be able to explain what they do if I should use them or not. thanks a bunch!
Old Jun 29, 2004 | 08:00 PM
chuckie311's Avatar
use the gm one. you dont need a a relay. you just hook it up to the rpm wire and the other side power and that it.just run all the vacuum and your done
Old Jun 29, 2004 | 08:12 PM
awesome, do you know what the relay is there to do and why I should not use it? And for the gm solenoid does it matter which one i get...
1997152 $18.48 $12.94
Fuel system - Fuel induction - Turbo charger - Solenoid
SOLENOID, Syclone, Typhoon 1992 - 1993
Fuel system - Fuel induction - Turbo charger - Valve
VALVE, TURBO BOOST VALVE, All Models 1989 - 1991
both came up with search, thanks again
Old Jun 29, 2004 | 08:18 PM
chuckie311's Avatar
you dont need a relay. this is all you need it acts just like a realy since it is a solenoid for a turbo its kinda like an all in one.. thats the right part number dosent matter which one you order.are you useing the summit rpm or the harlan rpm switch.
Old Jun 30, 2004 | 02:15 AM
great thx chuckie
Old Jun 30, 2004 | 07:14 AM
chuckie311's Avatar
great thx chuckie
no problem if you need help with it at anytime just let me know.
CorollaULEV
30
Aug 9, 2021 08:11 PM
maxprivate
Forced Induction
21
Jul 8, 2017 09:48 AM
homeofbacon
Sep 23, 2015 07:17 PM
doobadoo
Aug 15, 2015 06:43 PM
