Is this grounding kit any good?
I like the way it looks, but is it any good?
http://cgi.ebay.com/ebaymotors/ws/eB...908400639&rd=1
thanks
thanks
Looks like a knock off of the HKS version. If you can get it for cheap, go for it.
thanks
thanks
does is matter that each wire is only 8 gauge and not bigger? I'm not sure if they should be 4 guage or not, but seeing as how there is only one 4 gauge wire for ground in my car now, four 8 gauge wires might be enough.
Originally Posted by Tyrexx
10 bucks worth or sub wire.
what about the ring terminals/connectors? What guage wire did you use? How did you connect all the wires to the negative terminal of the batt without a distrubtion block of some kind?
I just soldered on some autoparts store terminals / 8 Gauge / Theres 3 8gauge wires comming off the 2nd negitave terminal, then I just soldered those to the other wires.
Originally Posted by XoPtOn
can someone just give me a quick answer to what a ground wire is and what it does?
What does it do for the car?
wires can only handle so much electricity. if the car pushes too much amps the wire will break causing electrical fire. ground wires privide basic protection from that overflow. a ground wire privides a path of least resistance for electrons to flow back to ground in case of overflow. (management information system major)
When you upgrade your grounding wires, you usually get a better (Smoother) idle, better Mpg (slightly), and a little more power (especially if your grounds are already jacked). This is usually why people upgrade thier grounds other than engine bay dress-up, and it's so cheap I wonder why everyone doesn't just go do it, it's well worth it.
Where all should I ground my car under the hood when i do it? Engine block and chassis are the only 2 i know to do. what others should I do?
As far as what the hyperground kit does, it's just adding more surface area for current to flow back to the negative terminal of the battery. The 4 ga wire would be better, but the difference between 8 and 4 is very negligible. It will never be noticed. I have 8ga on mine.
The big thing that needs to be done is that when you install this, take some sandpaper and hit every surface you bolt a terminal to with the sandpaper. For some reason, the connectors that are currently on the Max are bolted to a PAINTED surface! Also, put some dielectric grease on the connectors to aid against any rust or chemical reactions that may occur over time.
drew
thanks a lot for the link.
One more Q. If i were to make the grounding kit myself, how would I get all those wire connected to the negative terminal. its almost like I have to buy one of the kits on ebay just for the round plate looking connector.
Just find some scrap metal or hit up home depot or lowes. You would need a drill or drill press would be even better and something to cut it with. Just drill the holes big enough for the size bolts your gonna use.
You could also go to advance and get on of the battery terminals that has a wingnut on top of it with a bolt coming out of it. Then just place all the connectors from the ground wires on that bolt (one on top of the other) and tighten the wing nut. This would be the easiest way to do it.
I bought mine off eBay for the simple fact that I really didn't feel like messin with it. You'd only end up saving $10 or so unless you already had all the parts leftover from a previous sound system install.
Good luck
drew
MAXSE5SPD
Aug 23, 2015 12:06 PM
doobadoo
Aug 15, 2015 06:43 PM
