Alignment prob > Camber Kit???
Old Jul 2, 2004 | 01:01 PM
Xugg's Avatar
Recently I lowered my car with some Tokico Blues + Springs and after balancing my 18's along with an alignment job my car still pulls slightly.
Im thinking it might be the camber that needs to be adjusted but how do you go by installing a camber 'kit'? Do I need a tokico specific kit or will anything for a 4th gen work? Does this kit replace current suspension parts or does it bolt right in? If you guys know of any good nissan camber "HOW-TO's" that would be great, Thanks in advance.
Old Jul 2, 2004 | 02:11 PM
XeroX's Avatar
Hella internets
camber "plates" are available from stillen...other than that...all i have heard of is Camber bolts.. but if you have Tokiko blues, you shouldnt be dropped too low, therefore you shouldnt need to adjust your camber..
The stock camber bolts have enough play untill you go lower than 2 inches, THEN you will need camber plates or bolts...
Old Jul 2, 2004 | 02:42 PM
Xugg's Avatar
Originally Posted by XeroX
if you have Tokiko blues, you shouldnt be dropped too low, therefore you shouldnt need to adjust your camber....
....The stock camber bolts have enough play untill you go lower than 2 inches, THEN you will need camber plates or bolts...
I was thinking the same thing, the drop on tokico isn't lower than 1.5" so I'm in the clear I hope. Thanks for clearing that up and the quick response!
Old Jul 2, 2004 | 05:25 PM
njmaxseltd's Avatar
Post your alignment specs and I'll tell you why it's pulling. You should get a print out from the shop.
Old Jul 3, 2004 | 11:12 AM
toofast240's Avatar
I paid $20 for some camber adjustment bolts from Eibach. However, the most overlooked thing when talking about alignment is the tires. You have to take a look at your tread pattern too. I have 18's with Kuhmo Ecstas. After alignment, with my 16's, it drives as straight as an arrow. With the 18's, it pulls to the right a bit. Not enough to be dangerous, but there is a slight pull that is not on the 16's. So it is definitley not my alignment.
Old Jul 3, 2004 | 11:40 AM
nismology's Avatar
Let your springs settle completely before you get the alignment done.
Apr 16, 2020 05:15 AM
DC_Juggernaut
Sep 28, 2015 04:07 PM
Pied
Sep 26, 2015 03:29 PM
