Rewired Cornering Lights...Cheston Chiu THANKS
Old Apr 1, 2001 | 12:37 PM
zagato27's Avatar
Had some time this afternoon and decided the time was right to rewire my cornering lights. I'm not an electrical genius nor a car mechanic but with the instructions supplied by Cheston Chiu it was a breeeeeeez. There is a marked difference in the corner lights now If you are thinking of doing this it's easy. Great tip on the WD40 to loosen up the little ball joint on the corner light housing. I initially put in some hyperwhites about a month ago and it was a bear taking them out. Thought I was going to break either the corners or the headlights. Using the WD40 they popped right out.
Thanks Cheston and thanks to all in the forum. I've gotten great info and help from you all. I think that I might even have helped someone too I'm getting ready to install some diamond cut clear fronts and hopefully at the same time I'll rewire my fogs and maybe even do the sidemarker blink thing. With help like this it should be a snap. Thanks again!
Sir Tilus
Mar 22, 2016 01:49 PM
NERDJUSTBNME
Sep 30, 2015 03:20 PM
Blkkn8
Sep 22, 2015 06:37 PM
tnewbs
Aug 28, 2015 10:15 AM
Blackwind
Aug 5, 2015 06:35 PM
