What Makes the needles in the gauge light up??
Old Jul 5, 2004 | 08:04 PM
superblack98se's Avatar
I changed my gauges to 194 Blue LED's now the needles arent lighting up?? Where do they get there power from?
Old Jul 5, 2004 | 08:22 PM
Max Mutes's Avatar
Do you have stock guage faces? Also, do you have any pics? Sorry I couldn't answer your question, but I've always wanted to keep my black guage face in my I30 and have blue light come out instead of an off white light. Was never sure if it was possible to do or not. *shruggs shoulders*
Old Jul 5, 2004 | 08:32 PM
Guttermouf5150's Avatar
i'm not sure about 1998's, but on my 1997 its the same bulb. i put blue led's and the gauges and needles are both blue.
see
Old Jul 5, 2004 | 08:35 PM
Keyser Skoze's Avatar
see
Looks really good bro. I was actually thinking about doing this cause i have not seen any gauges that look better then the stock ones. But i have a 98 so it may be different then yours. Any ideas?
Old Jul 5, 2004 | 08:45 PM
Max Mutes's Avatar
Wowww. That came out hot. That's exactly what I was talkin bout. What type of Blue LED bulb did you use and how many were needed? Thanks alot for the pic.
Old Jul 5, 2004 | 08:47 PM
RA030726's Avatar
I'm nutty for Nissans
the se's from 97-99 have red (amber/orange) needles. Blue will not go through so the needles wont light up. either change the needles or the bulbs or live with it.
Old Jul 5, 2004 | 08:48 PM
this is what araffio told me a while back:
"98-99 gauge clusters do not use 194 wedge bulbs in the gauge cluster, we have much smaller wedge bulbs which are hard to find. It's possible to solder in 194 bulbs to ours though."
Old Jul 5, 2004 | 08:50 PM
ah thats good to know. i'm glad i got the SE cluster from a 1995 then. i had no idea, it just happened to be the one i found.
Old Jul 5, 2004 | 08:53 PM
hey thanks!
http://www.superbrightleds.com/cgi-b...gi?product=CAR
i used the WLED-6 LED bulb. it's the first 194 type bulb on the page. there are 5 of them total in the cluster.
Old Jul 5, 2004 | 09:17 PM
Max Mutes's Avatar
hey thanks!
Just to double-check and make sure before I start ordering, it's this one correct:
T13-B6 Blue LED bulb 12VDC Blue 6-LED Wedge Base bulb measure 1 1/8 long by 1/2 inch maximum diameter (194/168 type)
Old Jul 5, 2004 | 09:19 PM
Maybe i need brighter bulbs than the ones i have, I got them from superbrightleds also, but I got WLED-B
Old Jul 5, 2004 | 09:35 PM
no this is the one i have.
WLED-6 LED bulb
12 VDC 6-LED Wedge Base bulb (194/168 type)
Our brightest bulb of this type
that one will work too, but they told me that this one is brighter.
Old Jul 5, 2004 | 09:39 PM
i should note that i actually had problems with the first batch of them that i ordered. some of the led's stopped working, but some still worked. on the same bulb even. like, four of the six led's on the bulb would work. this happened after like three weeks. but, i should also note that they took care of it very fast. i called them and told them what happened, and they sent me a new set asap!
at first i had a problem with the new ones too, but i just had to bend the metal contact wire over a bit. been working great so far!
Old Jul 5, 2004 | 09:44 PM
Max Mutes's Avatar
Oh ok, I found it now. I was just lookin at the blue colored base LEDs, so I skipped over that thinkin it was a white LED, not knowing it was actually 4 different color types to choose from. Thanks again man. I appreciate it.
Old Jul 5, 2004 | 09:48 PM
don't forget about the hot spots too. just so your not surprised the first time you turn them on. i was. you get used to it though. if you look at the pic you can see them. they are pretty bright. i think it's worth it though.
Old Jul 5, 2004 | 09:57 PM
Max Mutes's Avatar
Is that them on the 30, 100, 2.5 and 7? To me, if that IS them they don't look too bad. Is it extremely bright in person or just a little bit of a noticeable difference? But yeah, either way, regardless it still looks hot. LoL, no pun intended.
Old Jul 5, 2004 | 10:51 PM
it's fairly noticeable. nothing extreme. like i said, though, well worth the look.
Old Jul 6, 2004 | 12:01 PM
RA030726's Avatar
you can always sand the leds to make the beam pattern/viewing angle wider.
Old Jul 6, 2004 | 04:21 PM
have you done that yourself?
btw, what type of midpipe do you have on your intake?
Old Jul 6, 2004 | 04:37 PM
pocketrocket's Avatar
I can see the hotspots, but do they illuminate the needles and odometer window evenly?
I have reverse indiglos in there right now, awesome but I need a brighter, and even source for just my needles and odometer window (1995 SE).
Old Jul 6, 2004 | 05:39 PM
ogparjay's Avatar
the blue LED setup looks tight, i might just have to cop your style.
Old Jul 6, 2004 | 05:48 PM
ogparjay's Avatar
how many LED's do you need to do this setup? that's just dope.
Old Jul 6, 2004 | 06:33 PM
OneToughMax's Avatar
Guttermouf5150, are you able to dim the cluster still, or are the led's at the same luminosity all the time?
Old Jul 6, 2004 | 08:44 PM
MyMaxRocks96's Avatar
Now I know what I'll be ordering tomorrow...
Quick question, I have a '96 GLE, how many of these LED bulbs do I need for the entire cluster? Stupid me when I had the damn thing out on the table the other night I never counted the amount of bulbs in there.
Old Jul 6, 2004 | 09:27 PM
you need 5 of the led bulbs, and yea they do dim from the dimmer switch.
oh yeah and i can see the odometer just fine. and as you can see, the needles light up just fine too.
i was driving tonight, and i noticed that they aren't quite as bright as they look in that pic. they are bright, just that they look a little brighter in that picture.
Old Jul 6, 2004 | 10:02 PM
greenmax95se's Avatar
WLED-6 LED bulb
looks sweet. i was wanting to do this bad. now i think i will will the same bulbs work for a 95-96 se cluster? thanks.
-rafal
Old Jul 6, 2004 | 10:22 PM
-rafal
yeah i have a cluster from a '95 in my car
Old Jul 7, 2004 | 11:33 AM
RA030726's Avatar
Guttermouf5150 i have a custom made midpipe...just a piece of intake tubing left over from a friend and 2 nipple/barb thingies from homedepot. To finish it off a breather filter and Arospeed coupling and reducer.
I have sanded the leds, did it for my climate control. No hot spots at all.
Old Jul 7, 2004 | 03:10 PM
how much sanding is involved? just a little off the tip? or...
Old Jul 7, 2004 | 03:49 PM
RA030726's Avatar
yea just ruff it up
Old Jul 9, 2004 | 11:35 PM
Max Mutes's Avatar
My fault Guttermouf5150. I forgot that the White SE Gauges are the same style as the regular Stock Black ones. This whole time I thought you had black ones and put the Blue LED's in. Either way it looks hot, but I want to keep my stock gauges, but still have Blue LED's. Would this work or no? Has anybody tried this or have this?
Old Jul 10, 2004 | 12:28 AM
well im sure they are not all that different looking. but no, i have never seen with the black gauges.
homeyclaus
Sep 3, 2015 06:15 PM
Rage Maximus
Sep 3, 2015 12:26 PM
Justinmc760
Aug 23, 2015 03:10 AM
acw
Aug 13, 2015 12:50 AM
kirkhilles
Aug 8, 2015 10:53 AM
