speed bleeders
Old Jul 7, 2004 | 11:21 AM
Maxima_Joe's Avatar
4th Gen Parts King
speed bleeders
which one does everyone get the steel oem version for 7.00 dollars or the ss one for 15.00 dollars?
Old Jul 7, 2004 | 11:34 AM
NmexMAX's Avatar
dot dot dot ...
www.speedbleeder.com set of 4 for 42 dollars.
Not sure if you know there is no such thing as an OEM speed bleeder. Speed bleeders have a small spring which lets you bleed your brakes w/o the aid someone else. And OEM units are just a small valve that closes when you tighten it.
Or you may just mean the material of the aftermarket version, I'd stick with SS.
Old Jul 7, 2004 | 11:39 AM
Masrekah's Avatar
Not sure if you know there is no such thing as an OEM speed bleeder, they have a small spring which lets you bleed your brakes w/o the aid someone else. And OEM units are just a small valve that closes when you tighten it.
What do the OEM Speed bleeders enhance? I'm new at all this...pleaes explain.
Old Jul 7, 2004 | 11:46 AM
NmexMAX's Avatar
dot dot dot ...
OEM is Original Equipment Manufacturer, so if you bought OEM, you'd buy exactly what came with the car so nothing is enhanced or better that original.
And the rest is in my last post.
Old Jul 7, 2004 | 11:50 AM
Maxima_Joe's Avatar
4th Gen Parts King
this is directly from the site
Introducing Speed Bleeder... The automotive bleeder screw with the built-in check valve that makes bleeding your brakes truely a one person job! Simply remove your OEM bleeder screw and replace it with Speed Bleeder. When you are ready to bleed your brakes loosen the Speed Bleeder 1/4 turn. Pump the brake lever or pedal until bubble free fluid is seen. Close the speed Bleeder and you are done. Anyone can do it! Speed Bleeders are priced at $7.00 each for the OEM steel version and $15.00 each for the Stainless Steel version. ........ .................................................. ...........Place your order using the shopping cart system. When you get to the order confirmation page state the year, make and model of the vehicle that you are ordering for in the comment box.
Old Jul 7, 2004 | 12:01 PM
NmexMAX's Avatar
dot dot dot ...
It's the the OEM MATERIAL, stainless or regular practially the same, the stainless wont rust, thats the only difference. If you live where rust is a big deal, go with SS, if you dont, then normal steel is fine
Old Jul 7, 2004 | 12:29 PM
Maxima_Joe's Avatar
4th Gen Parts King
did they raise there prices since when you bought them? did you buy the ss ones
Old Jul 7, 2004 | 12:50 PM
NmexMAX's Avatar
dot dot dot ...
No, I dont have to deal with rust so much where I live so I bought the normal steel versions.
Shipping and all that total came to $42
Miket2006
Mar 1, 2021 03:55 AM
knight_yyz
Nov 1, 2015 01:34 PM
uttadms31
Sep 30, 2015 05:24 AM
Marc2theMax
Sep 28, 2015 08:13 AM
