Downstream o2 question
I have a 0510, and a 0512 codes.
Both downstream voltage faults, I think.
Does this rob performance at all, or is it a minimal problem?
________
Anksunamunn
________
Anksunamunn
Originally Posted by C3nthusiast
You have 99...I pulled downstream O2 sensor, knock sensor, and ignition signal circuit code. I replaced coil pack #2 and haven't had a CEL since.
0510 is Downstream oxygen sensor Maximum voltage fault
0512 is Downstream oxygen sensor high voltage fault.
these are the only two codes i have...
when you say you "pulled", what do you mean, replaced? and why replace your knock sensor and coil pack 2 from a 0510 or a 0512?
________
Club Royal Condos Pattaya
what are you talking about? code 0304 is knock sensor circuit fault.
I determined I had a coil pack problem because my SLIP and TCS light would come on and the engine would sputter at a stop.
I determined I had a coil pack problem because my SLIP and TCS light ( I have tractio control) would come on and the engine would sputter at a stop.
If you get high voltage problems, then most likly ur O2 is shot. Replace it. An easy way to test is check the resistance. If very low resistance or none then ur O2 is bad.
This is off the top of my head, so I could be completely wrong. Do some search on google about testing O2 sensors, should be easy.
thanks yall.
C3nthusiast, i thought you were saying that my knock sensor was bad! scared
me a bit.
BTW, what is SLIP and TCS light?
________
Portable butane herbal vaporizer handheld
me a bit.
________
Unclejunebug
Apr 2, 2016 05:42 AM
Stagnet04
Oct 11, 2015 08:16 PM
