Cutting Sprints??
Old Jul 10, 2004 | 05:33 PM
sean05's Avatar
Cutting Sprints??
Hey guys,
i was going to order sprint lowering springs but i hear that the rears need to be cut to make it sit even. How hard is this to do? What do i need to do it? Anyone have a write up or pics? I dont really have alot of tools.
Thanks guys
Sean
Old Jul 10, 2004 | 10:57 PM
ch13f's Avatar
A hacksaw is all you will really need. People sometimes cut one coil off each of the rear springs to make the car sit evenly. If you have a big stereo in the trunk it might not even be needed.
Old Jul 11, 2004 | 06:28 AM
sean05's Avatar
I dont have a big stereo. So just a hack saw? How would i cut it? Is there any certain way i need to cut them?
Old Jul 11, 2004 | 07:55 AM
matty's Avatar
Dremel...
First I used an all mighty shawz all with my buddy....it shook the srping way to much and didnt cut anything...then I secured it on a bench and took a Dremel with a cutting bit on it...worked perfectly
-matt
Old Jul 11, 2004 | 10:08 AM
1FSTMAX's Avatar
Angle grinder works best...
Seems that you don't have too much mechanical expierience... Make sure you know what you are doing..
Old Jul 11, 2004 | 11:48 AM
Pimpmobile's Avatar
don't cut springs cause other susupension issuse (just from what Ive heard)?
Old Jul 11, 2004 | 12:00 PM
nismology's Avatar
They're talking about cutting off a dead coil which has no adverse effects.
Old Jul 11, 2004 | 12:08 PM
Nismo3112's Avatar
Custom User Title
Make sure you cut whole coils, or else the top part of the spring won't be aligned with the spring seat.
Old Jul 11, 2004 | 12:46 PM
sean05's Avatar
No its not that i dont have mechanical experience, but its that i dont have many tools. I just havent worked with springs before and im not sure what i need to cut off. Does anyone have pictures of the springs so i can see what i will need to cut off?
Sean
Old Jul 11, 2004 | 04:11 PM
drewm's Avatar
Why not just buy Tien S-techs? They are just as low as sprints without the high rear.
Old Jul 11, 2004 | 04:56 PM
sean05's Avatar
Everyone i talk to says that the s techs arnt as low as the sprints.
Old Jul 11, 2004 | 05:34 PM
1FSTMAX's Avatar
Sorry Drew, but I have to disagree. My friend has s techs with agx's, and the front sits lower in the front compared to sprints. But the rear is a different story, the stechs sit higher than un cut sprints. Now that i have cut 1.5 coils out of my rear sprints, the car sits even and lower than my friends.
Old Jul 11, 2004 | 06:05 PM
sean05's Avatar
What did you use to cut your springs. Do you have a pic of the coils of what to cut off?
James92SE
142
Jan 2, 2024 09:23 AM
magiconthetire
Oct 26, 2015 09:03 PM
RealityCheck
Oct 2, 2015 06:34 PM
Taino14
Sep 24, 2015 02:51 PM
