Update on VQ35 6 speed swap
Old Jul 28, 2004 | 08:36 PM
  #81
DaBombX's Avatar
I dunno where Hayward is but I'll be sure to drool all over your car in about a month after I move to Cali~
Old Jul 30, 2004 | 09:34 PM
  #82
MiniRX7's Avatar
1234567890
Old Jul 30, 2004 | 09:57 PM
  #83
jdm71488's Avatar
Originally Posted by MiniRX7
1234567890
did i miss something??? anyways, good luck man!
Old Jul 31, 2004 | 12:00 AM
  #84
Maximeltman's Avatar
Dammm, I used to live in SF and Oakland CA, the Bay area. DAMM... I would so go check u out man. keep truckin!
________
Avandia Class Action
Old Jul 31, 2004 | 12:21 AM
  #85
AKM2k5's Avatar
Are you gonna give them food and lodging?.... you know im kidding..
Originally Posted by vsamoylov
anybody that wants to see the car can come buy and check it out
Old Jul 31, 2004 | 09:41 AM
  #86
vsamoylov
heck no, do i look like a holiday in? but there is nothing really to see right now. when the engine goes in and all the wiring, then there would be something to see. but i am still waiting on parts and ups takes too long.
Old Aug 1, 2004 | 02:06 AM
  #87
AKM2k5's Avatar
You look like a ramada inn.. Im coming!!!
Old Aug 1, 2004 | 06:32 PM
  #88
BlackBIRDVQ's Avatar
drag racing is for wussies
I have done a 6spd conversion on a 00 Maxima and the tranny mount will not line up Check out my cardomain website. Also you gonna need to swap out the ignition switch- since your 4th gen has no immobilizer and all 5th gens have it. You are gonna have to cut the firewall up to pass the shifter cables throught it- they don't fit. I recomend doing this now as there is no room behind engine to drill once the engine is in the car. I would just slide in a VQ35DE block under the DE-K heads and use the variable manifold, keep all the wireing and dissable the troublesome VTC system. I'm gonna do a similar thing to mine soon with the new VQ40DE, but I'm not gonna put in the crappy 6spd tranny in.
Old Aug 1, 2004 | 09:48 PM
  #89
stephenlc's Avatar
What the difference between the VQ35 and VQ40? Crank and piston size? I bet you it has lower compression than 10:3:1 like the 3.5 maxima. What kind of tranny are you going to use Black Bird?
Old Aug 1, 2004 | 09:54 PM
  #90
stephenlc's Avatar
Hey Blackbird I went to your site, do you like your phantom grip, I am deciding on if I want one when I finish my turbo project.
Old Aug 1, 2004 | 09:55 PM
  #91
No specs have been released on the VQ40 engine, the heads are totally different from the current 3.5L. Nissan has its R&D department around my work and I talked to Yiko the guy who does alot of testing for Nissan at one stop light. I got to check out the new Pathfinder in person a month ago. The intake manifold is different and resembles more of a VK56DE than the 350Z one. I'm gonna use my rebuild-15K miles ago 5spd tranny with 100K miles on it. 6spd tranny sucks up too much WHP compared to the 5spd in the 3.5L Altima- ever notice how Altimas put out way more power than Maximas with bolt ons ?
Old Aug 1, 2004 | 10:15 PM
  #92
I removed it cause I noticed some metal shavings coming off the block- aka the PhantomGrip. I tried to install a PG in Y2K Max Luv's Maxima, and it didn't fit- required gridning down the spider gears which weakens the diff. Both of our Maximas- Brandons and mine are PhantomGrip less. I no longer recomend them on Maximas
Old Aug 1, 2004 | 10:50 PM
  #93
vsamoylov
yeah but then i will not have all 245 horses form a vq35 and no pint in the swap then. and what other tranny is there that i can use? and you want to buy the kit for the vq40de?
and i know that i have to drill a hole but my bro and i didnt do that on hs max when we converted to a vq35 6 speed in his 2k max. everything went perfect.
and i am using all the wiring from the 2k2 max so i hope everythin works. plus i will get all the neat features that the 5.5 gens have in a 4th gen.
ohh and a little secret, the 2k engine is out as of saturday.
Old Aug 1, 2004 | 10:59 PM
  #94
AKM2k5's Avatar
Yay!! Cant wait until everything is done!
Old Aug 1, 2004 | 11:04 PM
  #95
I doubt U didn't have to drill a hole in a 00 Maxima to do a 6spd conversion, got any pics to prove ? I know this from experience, I just put a 6spd into a AUTO 00. Check out my CarDomain site for pics, I aint BS here. 2K engine is out as of Saturday ?? it don't look like a 00 engine in any of the pictures... its a plane jane non-K motor you have. 245 horses ? Maximas had 255 and Altima had 240 in 02 and 245 in 03. 6spd only dyno 200-205WHP stock, which aint much more than the 00-01 5spd. Also how are you going to run returnless fuel system in your 4th gen ? Your going to run into ALOT of trouble pretty soon with all the emission equippment, shifter cables and motor mounts There is no kit for a VQ40DE, there is an actuall 4.0L VQ in the 05 Pathfinder, Frontier and Xterra. If your bro had a 5spd manual and went for a 6spd... that has to be one of the dumbest moves ever... you LOOSE power with that tranny. Compare dyno charts of Altimas vs Maxima and you see that 6spd makes less HP, same thing goes for the Spec V SE-R and just plane Jane SE-R, Spec has the same tranny as the 6spd Maxima, and on paper it has 175HP vs 165 for the normal SE-R, yet for some reason the normal SE-R puts out 5WHP more than the more powerfull Spec V. Good Luck with the swap, and I would like to see your brothers 00 6spd Maxima pictures.
Old Aug 1, 2004 | 11:08 PM
  #96
VQ30DE 95-99 Maxima.
VQ30DE-K 00-01 Maxima.
Old Aug 1, 2004 | 11:49 PM
  #97
vsamoylov
well i guess u havent been reading up on the posts from a long time ago. it is a 2k engine that was in my car but not he VI intake manifold. i was thinking of putting it on since people did it already but decided to go for the vq35 instead.
and u didnt read right. my bro went from a auto to a 6 speed. and he didnt cut a whole cause he used a vq35. he has a 2k 6 speed maxima with vq35 in it. he replaced everything including the harness inside the car.
and actually maxima is 245 horses. not 255. nissan only says that. a 2k2 max has been dynoed in numerous magazines at 245 horses. nissan lies on their #.
and i know the motor mounts and tranny mounts are different but i have all tht from a 2k2 parts car that i bought. so this swap is going to be alot easier cause i have evreything i need including the emission stuff. and i didnt have any emission problems with my 2k engine.
and i dont care if a maxima makes a couple less horses than a altime .i rather have a 6 gear for freeway cruising.
and then u are telling me i will have problems. look at the swap you are talking about. if it ever gets done.
Old Aug 2, 2004 | 05:15 AM
  #98
pictures, I would like to see a 00 Maxima with a 3.5L 6spd in it. Especially since you say there was no firewall cutting. What swap are you talking about here, that will ever get done ? My VQ40DE ? I guess U have not visited my Cardomain site and seen the cars I have. Engine swaps for me are like doing oil changes on Maximas.
Old Aug 2, 2004 | 06:53 AM
  #99
stephenlc's Avatar
Black Bird you posted your g20 instead of a VQ30DEK. Omg you put the VQ30DEK inside the G20 or is that 3rd gen maxima? Is that photoshop?
More props to you if it is real.
Old Aug 2, 2004 | 07:08 AM
  #100
MaxSpeedSE's Avatar
Black bird, when you say "I would just slide in a VQ35DE block under the DE-K heads and use the variable manifold, keep all the wiring and disable the troublesome VTC system."
I agree it would be easier. But i still hope this Vq35 project comes three due to a couple reasons. Combining the motors will make the compression shoot to a 11:1 i believe. This isent too good for us people with forced induction. A Vq35 would put down the same power at a safer compression for us to run our forced induction and it would be perfectly tuned by Nissan.
Just my 2 cents
-Chris
Old Aug 2, 2004 | 10:23 AM
  #101
vsamoylov
i seen your cardomain page. props to you for doing these swap also. it is always cool to see somebody else enjoy the same type of things.
i get pics of my bros 2k with vq35 6 speed. you never seen the pics before?
Old Aug 2, 2004 | 10:48 AM
  #102
AKM2k5's Avatar
Blackbird, you remember that huge thread we had with us 3.5 guys trying to get a lawsuit in for missing HP? Well thats what hes trying to say. Vsamoylov, I think the max engine make around 255hp, but there too much powerloss by the time it get to the wheels.. If not, nissan needs to buy all the 5.5 gen 3.5 maximas back.
Old Aug 2, 2004 | 12:09 PM
  #103
vsamoylov
well i got the engine out and it is in my garage now. now i am wondering if the intake manifold of the vq35 will clear the hood. if not, hood scoop. i get pics of the car and the engines up and the vq35 6 speed in the 2k max also.
Old Aug 2, 2004 | 12:15 PM
  #104
AKM2k5's Avatar
Why not just make a custom hood with raised sections where it may have clearance issues?
Old Aug 2, 2004 | 12:24 PM
  #105
vsamoylov
you mean like on the eclispe? kinda like a hump? i rather have a scoop.
Old Aug 2, 2004 | 12:29 PM
  #106
AKM2k5's Avatar
lol.. not the hump.. I dont know I was just picturing something like the Mustang Cobra R where the hood is raised :
Old Aug 2, 2004 | 12:35 PM
  #107
vsamoylov
yeah that would look good but i have no idea of how to make that from a stock hood unless i get aftermarket hood but i like the idea cause a scoop wont look right.
Old Aug 2, 2004 | 12:44 PM
  #108
AKM2k5's Avatar
The scoop will just make your intentions of making your maxima look from classy and powerful to just being ricey... Im sure youlll figure something out about the hood.. You could always talk to a body shop and see what they can do for you.
Old Aug 2, 2004 | 08:01 PM
  #109
I have a 94 Sentra XE that I put a VQ30DE into but its on hold for now. Need to get some axles fabbed up. I dunno what possesed me to do a such weird swap. The picture you see is PhotoShop of my engine- U can see the 2x4 sticking out from the intake manifold. I use that 2x4 to hold up my CF hood when I work on the car Durring Photoshop it was cut off. I wanted to see what the K motor would look like under the hood.
Old Aug 2, 2004 | 08:05 PM
  #110
As far as 11:1 compression goes, I have a friend who has a 95 200SX SE-R, has 11:1 compression and all the all bolt ons, makes only 227WHP naturally aspirated and shoots 100 shot of JWT NOS into the engine with no problems. The new TL uses 11:1 compression also from the factory. I wouldn't worry bout 11:1 compression on 93 pump gas. There are many secrets of making a detonation free frankenstein 3.5L hybird.... you can add quench area to the heads combustion chamber area. This will lead to a less detonation prone engine. Dan Parramore Racing uses that on his race SR20 turbo heads for all out power. Our killer high HP 600-700WHP SR20s run 10:1 compression with no detonation and insane amounts of boost
Old Aug 2, 2004 | 10:14 PM
  #111
AKM2k5's Avatar
DONT QUIT the forum BLACKBIRD!!
Old Aug 2, 2004 | 10:22 PM
  #112
vsamoylov
BlackBIRDVQ, i have a quick question for you on headers. my headers on the vq35 were cracked due to the accident and do you think that 2k-2k1 headers will fit?
or should i get some aftermarket headers? what do you recomend? hotshot or cattman? which has more gains and is easier to install and no fitment problems? and what kind of money am i looking at to spend for headers? worht it?
Old Aug 2, 2004 | 10:34 PM
  #113
AKM2k5's Avatar
VSA, I think it would be much better in the end if you stick with getting 3.5 headers..
Old Aug 2, 2004 | 10:41 PM
  #114
vsamoylov
wh ydo you think it be better in the end to just get stock headers for my vq35? just to see the gains it will give being all stock? and then i have to buy and waste more money on aftermarket headers when i can do it now.
Old Aug 2, 2004 | 10:55 PM
  #115
AKM2k5's Avatar
oops, sorry for not beeing clear.. I meant hotshot headers.. Your prbably gonna want to mod the 3.5 anyway, so since you have to buy headers, might as well go ahead and get something good instead of wasting money later... (you posted too many threads about headers, I got confused what I was replying to )
Old Aug 20, 2004 | 06:53 PM
  #116
Wills98MaxSE's Avatar
1 of few unmodded 4G Maxs
any recent updates vsamoylov since the .org went down?
Old Aug 20, 2004 | 07:06 PM
  #117
DAVE Sz's Avatar
Hooooooonda.....
yeah, the thread he started BEFORE the org went down
Old Aug 20, 2004 | 07:11 PM
  #118
nismos14's Avatar
§è~® f®ÈÄk
there's a part two to it scroll around for it
Old Aug 20, 2004 | 08:17 PM
  #119
Kevin's Avatar
cant find it BRO...
Old Aug 20, 2004 | 08:46 PM
  #120
nismos14's Avatar
§è~® f®ÈÄk
There was an updated thread, why are you lookin for it anyway? Gonna swap a vq35 into you're car??
