Negative Camber, Lowered with bad inner tires wearing..Camber Bolts??
Old Jul 23, 2004 | 11:25 PM
95CustomMaxima's Avatar
I am wondering if Camber Bolts will help/solve my solution for my negative camber after lowering. Tires are wearing on the inner side of tire twice as fast as rest of tire. Will camber bolts solve my problem?? Also how hard/ how do you install the bolts? I now where they go but how do you adjust them. Any help is greatly appreciated.
Thanks,
-Nick
Old Jul 24, 2004 | 12:06 AM
VIP Maxima
i think its gonna fix it since bad camber is gonna make the wheels lean sidways.
Old Jul 24, 2004 | 12:21 AM
Ludacris's Avatar
I got the Eibach camber bolts and they worked perfectly...my camber is nowhere near as negative as it was before. Almost stock...and thats with a sprint drop
Old Jul 24, 2004 | 12:25 AM
Did you install them yourself? If so how did that go?
Thanks,
-Nick
Old Jul 24, 2004 | 12:28 AM
DAVE Sz's Avatar
Hooooooonda.....
Did you get an allignment?
Old Jul 24, 2004 | 12:48 AM
No but the camber is too much for an alignmen to fix.
Old Jul 24, 2004 | 02:16 AM
DAVE Sz's Avatar
Hooooooonda.....
And how do you know that? Unless the car is dropped 3"+ it's fixable. Something tells me that you made a few mistakes during the install, something to do with attachint eh struts to the lower control arms where that 19mm bolt goes. I had the same thing and then realized that before tightening that bolt I didn't push the rotor and hub up and towards the front of the car. That made the wheels be at an angle to the pavement.
Old Jul 24, 2004 | 07:51 AM
I know this because a. I installed everything right because I have done suspension before. b. I had no camber until I lowered the car even lower because I have Coilovers. and lastly c. I am at a 3 inch drop.
-Nick
Old Jul 24, 2004 | 09:07 AM
Ludacris's Avatar
Thanks,
-Nick
Nope...someone else did it...I got it done with an alignment.
Matt93SE
May 24, 2019 02:58 PM
Maxima_Joe
Nov 25, 2015 08:19 AM
homeyclaus
Sep 3, 2015 06:15 PM
FlaMark
25
Aug 28, 2015 10:15 AM
maxocar
Aug 21, 2015 12:57 AM
