code 0302
Old Jul 25, 2004 | 02:35 AM
joeynym's Avatar
Back in the Max
code 0302
check enginge lite went on, car running very rough, like if only rnning on 5 cyl, any suggestions on whats going on??????
Old Jul 25, 2004 | 10:08 AM
killcrap's Avatar
I'm actually quite pleasant until I'm awake
first check Ignition Coil, then check Spark. Lastly Check Injector. i've got some injectors for sale if anyone is interested.
Old Jul 25, 2004 | 09:50 PM
joeynym's Avatar
Back in the Max
thanks, bank 02 ing coil went bad, changed it today...
Old Jul 25, 2004 | 10:37 PM
DAVE Sz's Avatar
Hooooooonda.....
0302 is an EGR code, why did a coil set it off?
Old Jul 26, 2004 | 10:56 AM
joeynym's Avatar
Back in the Max
well, i looked on ecu site & it said something about egr, so i went to double check it , went to autozone & they scanned the comp & told me it was bank 2 ing coil, so i go home & pull out the coil & there was a a burn spot on it, went to parts store & picked up a new ing coil, my 6th cyl was back, what a difference
Old Jul 26, 2004 | 12:13 PM
killcrap's Avatar
ohm out all your coils. they probably are all bad, and need replacing.
Old Jul 26, 2004 | 09:55 PM
joeynym's Avatar
Back in the Max
what makes u think that?????
what do u mean by ohm is out
Old Jul 31, 2004 | 05:23 PM
Virtual ET's Avatar
what does 0302 have to do with the coil? i'm confused...
Old Jul 31, 2004 | 05:38 PM
unixadm's Avatar
You are a bit confused on the subject so I'll explain. There are two types of codes here. The codes that the ECM will flash on the MIL and the codes that an ODBII scan tool will pull. The later are called "P" codes and are industry wide OBDII codes. The code the Malfunction Indicator Lamp (MIL) will flash is specific to Nissan.
0302 = EGR System Hi/Low Flow (Nissan Internal Code)
P0302 = Cylinder 2 Misfire with the '02' portion of the code indicating the cylinder (OBDII P Code)
So in this instance if he would have pulled the codes through the MIL he would have got the Nissan specific code of 0607 indicating Cylinder 2 Misfire.
Old Jul 31, 2004 | 06:06 PM
joeynym's Avatar
Back in the Max
actually i received a mil code of 0302, it felt like i was running on 5 cyl, so i went to autozone & got the OBDII code , same thing 0302, but they told mecyl 2 misfire, changed the coil, power is now back........ thanks for all the info
maxinout93
Oct 31, 2015 02:04 AM
Kyle Lee Cleveland
Sep 28, 2015 09:01 PM
dshinn
Sep 26, 2015 08:07 PM
zmcneely13
Sep 26, 2015 02:26 PM
