View Poll Results: Are you interested in an Intake Manifold?
Yes, count me in!
156
88.14%
No
21
11.86%
Voters: 177. You may not vote on this poll
VQ30DE Intake Manifold?
Old Mar 26, 2005 | 04:41 PM
  #161
CaLSoNiC
Originally Posted by zack342
He just said they are in Arizona
He said they are in Arizona now, which means at one points they were not in Arizona...
Anyway... 1.5K for an IM? Thats like 1/4 of the price of a turbo kit. I dont see very many people jumping on that. But I would be hella insterested in the 00VI adapter. You might wanna try www.azmaximas.org and im sure someone down here will be willing to be the guinea pig.
Old Mar 27, 2005 | 09:47 AM
  #162
mad-max98's Avatar
yea im would be a bad idea cuze we already have the 00-01 one so it would be stupid to get one that won't come close as far as performance and for 1500?????!!!! i would rather get the 3.5 vq and have 100 extra hp all around or for the most part anyway
Old Mar 27, 2005 | 11:27 AM
  #163
SSR Engineering's Avatar
lol it won't be $1500, depending on what route we go it will be anywhere from $1-$200 for an adapter plate, and $6-$900 for an intake manifold (also we can run a group buy to lower the cost in the beginning)
Old Mar 27, 2005 | 01:42 PM
  #164
NmexMAX's Avatar
dot dot dot ...
Sounds like a good plan .. I want the adapter plate and maybe you guys could bundl an installation kit too ...
Old Mar 27, 2005 | 04:09 PM
  #165
d00df00d's Avatar
Old enuf to pick his own gears
I think it'd be important to note that a new intake manifold could be worth a lot more than extra hp on the top end. It might be good not to lose 30hp at redline, but a new manifold could be a ton more important as a facilitating mod -- i.e. one that helps you squeeze power out of other mods like an intake and exhaust parts.
Here's something to consider: when you're tuning a car on any kind of limited budget, whether it be $1k or $10k, you always take what your car is initially good at and work with that, right? That's why (smart) people bore out and supercharge muscle cars and don't do much to suspension, or focus on suspension first and engines second on Hondas.
Well, the VQ30DE is great because it's so flexible. It has good torque at low and midrange rpms, great balance and timings for good performance on the high end, and lightweight internals and short-stroke half-liter cylinders for quick throttle response. So you could theoretically take it anywhere:
1. Add a CAI and tune your ECU for low- and mid-range punch.
2. Throw on a short ram or hybrid intake, get some cams and bump up the redline for lots of high-end power.
3. Use a hybrid intake, open up the exhaust a lot, and put in an ultra-light flywheel and UDP to make it rev like a dremel.
A new intake manifold could do wonders in any one of these scenarios. A variable manifold could help for either low-end or top-end without hurting the other, and a manifold with individual throttle butterflies would make our engines even more revvy and responsive and really make them scream at the high RPMs.
Anyway, the point is, it's a total package thing. As has been pointed out, there really isn't a wide range of mods, especially one that can be installed relatively painlessly. A new intake manifold that opens up a new performance aspect for our engines, especially one that just bolts right up, would really be killer since it would allow a wider variety of setups to choose from.
Also keep in mind.... a product that's a couple hundred bucks more expensive than you'd like might still be a bargain if it saves you hours and hours of labor (yours or your mechanic's) and helps you avoid headaches.
SSR, a new intake manifold to help high-end power and/or engine response would be awesome by itself. If you could then show that it really rips in combination with other mods, you're guaranteed to sell them.
I would love to see an intake manifold that is tuned for high-end power and has individual throttle butterflies. I'd imagine you could easily get a couple of companies together to make tested and proven intake-manifold-ECU-exhaust-flywheel packages that work together to turn our engines into rip-roaring 8,000rpm rev monsters. Peak torque would come in at like 4500 and wouldn't stop until 7500 -- even if you did have low-end loss, it wouldn't matter because anyone who complains about it would get left in the dust.
Old Mar 27, 2005 | 04:34 PM
  #166
GoalieKeg's Avatar
I like the adapter idea for the 00VI, but why not a complete install kit that makes the 00VI a bolt-on mod? Let the customer source the manifold itself, and include a ready to bolt on TB (preferably matched to the manifold itself for even flow), and all the necessary hoses, bolts, etc? I would jump all over this, since 00VI's can be found at the junkyard for 150 bucks or less. Have the kit cost about 400 bucks or less, and I'm a customer.
Old Mar 28, 2005 | 10:11 PM
  #167
NmexMAX's Avatar
dot dot dot ...
Couldn't have said it any better.
Old Mar 28, 2005 | 10:30 PM
  #168
d00df00d's Avatar
Individual throttle bodies damnit!
Actually, a big for the 00VI bolt-on kit idea.
I'd still love to see something unique (like a full new manifold), but a kit like that would rock hardcore. I'd buy it in a second.
Old Mar 29, 2005 | 06:24 AM
  #169
nismology's Avatar
Another good idea is to make a lower intake manifold that would allow you to bolt the 00VI onto 3.5 heads.
Old Mar 29, 2005 | 06:41 AM
  #170
Ninos_Maxima's Avatar
be the change u want2C
2k1 bolt on idea ROKS ALL!!!
Old Mar 29, 2005 | 09:56 AM
  #171
laylow1988's Avatar
Originally Posted by SSR Engineering
We do not have any maxima's to work off of yet, 4th 5th or 6th generation.
do you want mines
Old Mar 29, 2005 | 10:10 AM
  #172
NmexMAX's Avatar
dot dot dot ...
Originally Posted by laylow1988
do you want mines
No, b/c then they would explode when stepped on.
Old Mar 29, 2005 | 10:12 AM
  #173
Ceasars Chariot's Avatar
Old Maxima Legend
im in on this idea as well !
Old Mar 29, 2005 | 10:43 AM
  #174
JClaw's Avatar
I'm in on that. Would be good not only for 2002+ but for people like me with VQ35's in their 4th gens.
Old Mar 29, 2005 | 11:09 AM
  #175
Zack342's Avatar
right now this thread is about 4th gen VQ30DE. I would be interested in an adapter for the 00 VI that was reasonably priced $400-600
Old Mar 29, 2005 | 11:11 AM
  #176
MSmax96's Avatar
i would love for that to come out!
Old Mar 29, 2005 | 11:30 AM
  #177
d00df00d's Avatar
Seriously tho, people.... I really (really!) don't mean to hurt the idea of an 00VI installation kit, but why not something truly unique? Is it because it wouldn't be worth the effort to try to improve on Nissan's design?
Old Mar 29, 2005 | 11:36 AM
  #178
NmexMAX's Avatar
dot dot dot ...
It's always good when you answer your own question.
Old Mar 29, 2005 | 11:43 AM
  #179
d00df00d's Avatar
I am obsessed with individual throttle butterflies. RB26DETT ownz me.....
Old Mar 29, 2005 | 11:45 AM
  #180
nismos14's Avatar
§è~® f®ÈÄk
I've got to agree here. It seems smart that something like that would sell alot, based on all the dyno #'s and all the people who have done it so far LOVING it and making me jealous lol
Old Mar 29, 2005 | 12:14 PM
  #181
NmexMAX's Avatar
dot dot dot ...
I am obsessed with individual throttle butterflies. ....
But not all of us are ... or can afford it, or at least not most of SSR's maxima market share.
Old Mar 29, 2005 | 01:03 PM
  #182
ManualMaxima's Avatar
5th Gen till she dies!
as everyone eles said if it acts liek a 5th gen vi and bolts up to the 4th i am in for it defiantly.
Old Mar 29, 2005 | 03:42 PM
  #183
Bonka's Avatar
Schnell kaputt
Any progress? I've got my MEVI sitting here so if this doesn't pan out I'm going to make time to install the MEVI. I don't have the time to do 2 installs.
Old Mar 30, 2005 | 08:12 PM
  #184
Zach95SE's Avatar
If you make an adapter plate plus an installation kit so it is a new bolt-on mod for us 4th Geners then you can count my money in your pocket.
Old Mar 31, 2005 | 12:09 AM
  #185
2k1 Install Kit + bolt on kit Yea yea
Old Mar 31, 2005 | 04:27 AM
  #186
Cant_Get_Ryte's Avatar
Chocolate_Boi_1Der
exactly. to spend a grand on an intake it would have to drop a large amount of horses and a flat tq curve from startup to redline. but with an adapter I can see that DEFINITELY being worth it and would be much better than changing injectors and all that bs.
Old Mar 31, 2005 | 06:11 AM
  #187
scrhale's Avatar
WOOT WOOT on 00VI adapter. I don't think you can beat that
Old Mar 31, 2005 | 06:17 AM
  #188
Zack342's Avatar
so what is the final verdict SSR ?
Old Mar 31, 2005 | 10:54 AM
  #189
All we need is a 4th gen, and an 01 VI Intake manifold
Old Mar 31, 2005 | 11:02 AM
  #190
gabex's Avatar
So if someone brought their 4th gen, and a complete 01VI (upper, lower, fuel rail, injectors, TB, EGR, IACV) maybe they could get the labor and kit free? (I know earlier was stated no free manifold, but since the kit idea would be less expensive, and be possible to do) AZ members should hop up on the opportunity.
Old Mar 31, 2005 | 11:03 AM
  #191
NmexMAX's Avatar
dot dot dot ...
You guys should still be in NM, I'd drop my 4g off with you guys and let you guinea pig away ...
I would be willing to buy the manifold and all hardware and have it shipped to you guys if there was something in it for me ...
Old Mar 31, 2005 | 11:49 AM
  #192
Zack342's Avatar
So this is going to be 4th gen lower manifold and 5th gen VI upper right?
Old Mar 31, 2005 | 12:26 PM
  #193
krismax's Avatar
Father of the 00 VI
MY advice dont make this for stock TB make it for pathy one and use dek lower. People have problems with coil packs using 4th gen lower
Old Mar 31, 2005 | 03:18 PM
  #194
So use a whole DEK manifold, and make it fit pathfinder TB? You guys do realize the more custom stuff the more it will raise the price, if it's made to fit the pathfinder you'll have to source and purchase a pathfinder tb etc.
Old Mar 31, 2005 | 03:31 PM
  #195
NmexMAX's Avatar
dot dot dot ...
Maybe have different stages, one just bare minimal bolt on adapter, the other Pathy Tb etc.
Old Mar 31, 2005 | 04:39 PM
  #196
Zack342's Avatar
that is why you should not do this. 4th gen lower and 5th gen upper only. and stock TB.
Pathy throttle bodies are hard if not impossible to source and you would make this mod difficult for many people.
the 4th gen coilpacks are only an issue on 99's so i don't see what what has to do with VI
Old Mar 31, 2005 | 07:13 PM
  #197
GoalieKeg's Avatar
Sourcing a 00VI manifold is enough, a Pathy TB is too much. Make it to fit the stock TB with an adapter (prefered), or have a custom one made. The main reason I brought about the kit idea is so that your average orger (not a dumb orger, we have quite a few of those, including me) will be able to install all the vaccum lines, EGR (with or without), IACV, etc. by following DETAILED (pictures are helpful) written directions provided by the manufacturer of the kit. There are in reality very few orgers that know what all the components are of the USDM or VI, or for that matter, how they even work. Perhaps an orger that has the 00VI on their car and understands it well can help out SSR with the fabbing or give them some ideas on the best way to do it.
Like I said before, if this happens, I'll be the first in line to order.
Old Mar 31, 2005 | 09:15 PM
  #198
d00df00d's Avatar
i'll be second!
Old Mar 31, 2005 | 09:23 PM
  #199
d00df00d's Avatar
Hey guys.... as a sort of a side note...
I sorta mentioned this in my huuuuge post a few pages back, which I don't really expect people to have read... The VI really helps on the high end, and some other mods (like shorter intakes) help there as well, right?
Well, what about the idea of an intake/manifold-kit/flywheel/exhaust/ECU combo, all of it optimized for power in high RPMs? Would anyone buy that?
Old Mar 31, 2005 | 09:49 PM
  #200
90stanza's Avatar
what GoalieKeg said sounds like a good idea to me.
