Steam cleaning your engine.
Old Apr 4, 2001 | 07:14 AM
SMX's Avatar
SMX
Did anyone try steam cleaning his or her engine using the direction from MaximaDriver.com.How2?
I you like to try it, But I want to know if anyone has tried it, and have they seen results. Is it safe to do?
Old Apr 4, 2001 | 08:40 AM
2ndMAX's Avatar
You're not alone...
I've seen this on Maximadriver.com and I've been very interested in doing it. I haven't heard anyone else trying it and either liking or disliking it. So whats the deal fellas???? Steam clean or no steam clean. Lets get some light shed on this topic. Where are all the Nissan mechanics on the board???? Is this steam clean thing for real??? Does it work???
Old Apr 4, 2001 | 09:08 AM
strattao's Avatar
Re: You're not alone...
I read about that too, and am considering doing it. However, this post from Daniel B. has got me thinking twice...
Don't do it!
Quoted Message:
Originally posted by 95greense
sorry bout that daniel. my last post probably wasn't very clear. the idea that i was actually talking about was to find a hose with vacuum and actually dip the hose into a container with water. the water is supposed to be taken into the engine and produce a "steam clean" effect inside the engine. then you are supposed to do the same thing with carb cleaner or something similar. these things were reported to cause the engine to run smoother. any thoughts on this?
Oh, inside the engine.
This idea is called Water Injection, and it's been around for years. The idea is that if your combustion chambers have a harmful amount of carbon deposits, the water (or carburetor cleaner) will get rid of them.
This scheme is what the scientists call "A solution in search of a problem". In other words, it cures a disease you don't have.
Don't do it!
__________________
Daniel B. Martin
Nissan owner and D-I-Y mechanic
Old Apr 4, 2001 | 10:25 AM
SMX's Avatar
SMX
Come ON! someone had to try it.
Old Apr 4, 2001 | 11:39 AM
kratz74's Avatar
I did it per the instructions and didn't notice any differece afterwards. It doens;t hurt but can only help. I did not have to blip the throttle cable to keep the engine running-it was just fine and sucked the water down quick and same with the cleaner solution. Hey for $2, why not?
Old Apr 4, 2001 | 11:55 AM
Maxwell's Avatar
Why not?
Because I'm AFRAID.
What if running water through the engine actually causes slight long-term damage? I don't want to risk losing even 5k miles off the life of my car. I'm not saying this would damage an engine, but honestly, it seems like nobody here has any idea.
Old Apr 4, 2001 | 12:51 PM
kratz74's Avatar
Daniel Martin already spoke to the issue. The engine runs at high temps which will cause the water to steam instantly and flow out the exhaust quickly. It's an old trick and does work. If you don't want to do it the don't, no biggie. Daniel thinks it works...
Old Apr 4, 2001 | 12:54 PM
Maxwell's Avatar
But pasted into one of the above posts is the explicit instruction by Daniel Martin not to do it.
Old Apr 4, 2001 | 01:07 PM
jahav's Avatar
I did do the "steam clean" and had the following results. Now bear in mind that changes in weather and day to day conditions can have the exact same effects described here so I'm in no way saying that this 100% solved problems since other variables (mainly weather) have not remained constant. Nonetheless here goes: I commonly experienced the strange starting problems described throughout this board. When letting the car sit for 3-4 hours I would have to crank the engine for a period longer than normal to get it to start. Ever since doing the water and fuel injector "steam cleaning" method, I have not had this problem reoccur once. It has now been 3 weeks since I undertook this simplistic project and like I said, I have yet to experience the starting problems that I normally occurred on a weekly basis.
Hope this helps,
Jeff
Old Apr 4, 2001 | 01:17 PM
SMX's Avatar
SMX
OK Jeff the direction say's not to use tap water. what type of water did you use? and what cleaning solution did you use.
Old Apr 4, 2001 | 01:28 PM
jahav's Avatar
In my steam cleaning procedure I did use the vavuum tube attached to the bottom of the boost sensor. I used store bottled distilled water and an alcohol based fuel injection cleaner (sorry don't remember the brand or exact type I'll see if I can locate it this weekend).
Type to 'ya later,
Jeff
Old Apr 4, 2001 | 01:29 PM
kratz74's Avatar
He said "don't do it" because not everybody needs it. It won't cause damage but may not be necessary. I'd suggest going to back to the original thread (months old) and read the actual verbiage for yourself rather than paraphrased portions thereof.
Old Apr 4, 2001 | 02:57 PM
strattao's Avatar
Update, Daniel B.?
Here is the link to that thread.
As far as I can tell Daniel B. says don't do it.
I would love to hear otherwise though. I'd like to do this if it would help.
http://forums.maxima.org/showthread.php?threadid=24985
Maybe Daniel B. can write us an update?
Old Apr 4, 2001 | 07:26 PM
JohnnyMax's Avatar
Pulling liguid water into the engine?
Sounds like the result might be Hydrostatic lock and broken connecting rods!
Don't do it
litch
123
Jan 4, 2024 07:01 PM
aw11power
Oct 10, 2021 04:57 AM
Apr 16, 2020 05:15 AM
fx4five
Oct 1, 2015 04:58 AM
