indiglo gauges
Old Aug 2, 2004 | 09:10 PM
cramez765's Avatar
indiglo gauges
When ur wiring up the reverse indiglo gauage where exactly is the headlight power supply that the positive and negitive wires conect to. I couldnt find it using the FAQ directions.
Old Aug 2, 2004 | 09:44 PM
NYC_Maxima97's Avatar
I'm not sure why you need those, but just connect it to the light dimmer switch, you can get the power from there. It works real well.
Old Aug 2, 2004 | 09:51 PM
cramez765's Avatar
thanx, im new with this stuff just got a 98 max and im learning.
Old Aug 3, 2004 | 12:12 AM
ManualMaxima's Avatar
5th Gen till she dies!
just do not connect it to the dimer switch like he said, connect the positive to the black and blue wire comming form the dimmer switch. this is not the acual dimmer switch buy the power sourse for the light that is on the dimmer switch. be sure to hopok that back up to.
and for a ground connect to any nut or screw behind the dash. touch it on metal things and see if it works.
Old Aug 3, 2004 | 10:10 AM
killcrap's Avatar
I'm actually quite pleasant until I'm awake
connect the ground to anywhere on the back of the cluster where it says GND
Miket2006
Mar 1, 2021 03:55 AM
220k+ A32
18
Sep 22, 2015 11:39 AM
RWCreative
Sep 21, 2015 11:01 AM
kadespraggins
Sep 14, 2015 12:04 AM
NissanNismoZ
Sep 12, 2015 07:30 AM
