95 Max Check Engine light, I reset it without fixing problem!!!
Old Aug 3, 2004 | 11:47 AM
Boothhead's Avatar
My check engine light came on yestarday in my 95 Max and I ran the diagnostics (the set screw in the side of the ECU) and i got the Error code 0503
I found this about that code on the forums:
0503
Diagnostic Trouble Code 0503 indicates a problem with the front Oxygen Sensor on the right cylinder bank. The right bank is also called the rear bank. It is cylinders 1,3,5. A normal signal sweeps back and forth between 0.2 volts and 0.8 volts. This malfunction was detected when the Engine Control Module received a signal from the sensor which was a constant value of approximately 0.3 volts.
Possible causes include ...
- Harness or connectors (the sensor circuit is open or shorted).
- Defective Oxygen Sensor
I reset the check engine light without fixing the problem. If the problem does really exist should the check engine light come back on sometime soon, or did I screw it up?
Thanks in advance.
Old Aug 3, 2004 | 11:55 AM
Jeff92se's Avatar
I'm needing a caw
It will come back if the ecu sees another out of range voltage from that sensor
beboski
Aug 16, 2015 05:23 PM
Flores94
Aug 11, 2015 12:53 PM
MikesChevelle
Aug 7, 2015 05:57 PM
bassmann
Aug 3, 2015 07:53 PM
