99 Maxima SE-L SRS light blinking
I have already looked in to FAQ/TSB threads. But I still have a couple of qustions. I'm sure it would have been discussed in the past. And I don't want to repeat the questions if it were already discussed. Since I don't have permission to search, could someone please post the search results on this problem?
Thanks a lot
Thanks a lot
Originally Posted by FormorAccordMan
If it has side air bags, its probably the culprit. I have had both sides replaced. POS!
One of the TSB's(for earlier models) talks about a weak battery could lead to this problem as well. I would like to know if it could also happen with 99 maxima. I know my battery is due for replacement. Wondering if a new battery would solve this problem.
Also I read about the reset procedure. I would like know if I do the reset and if there is a genuine problem with SRS, would the light start blinking again?
Originally Posted by milli
Thanks for your reply. Yes, it does have side airbags. I bought it used and from the previous owner's service history looks like they had this problem within months after buying it new and the dealer had done some work on side airbags.
I tried calling 1-800-nissan1 and they said it was the first they heard of the "side-airbag" problems....supposidly it has never been an issue or even brought to their attn....but they said if its out of warranty there is nothing they can do. I would just call and call and call.
It's blinking after reset by the dealer a couple of months ago. Last time I tried the reset procedure myselft and it did not work. So I had to pay the dealer to reset it.
Has anyone here successfully reset a blinking SRS using the procedure? Does the dealer reset it in a different way? I really don't want to pay the dealer this time just to reset it. Any help would be appreciated.
Frank, do you usually reset it yourself or go to the dealer?
I do it myself because it's no use paying the dealer to reset it. If you take it to the dealer, just do the work which is expensive. I don't even know why they would reset it, don't they tell you what's wrong when they charge you? When it was under warranty, I got a printout stapled to my receipt, it was the harness on the pass side airbag.
MikesChevelle
Aug 6, 2015 11:36 AM
yat70458
Aug 3, 2015 01:16 PM
