Low idle at stop lights, A/T
Old Aug 20, 2004 | 07:39 AM
Xugg's Avatar
About two weeks ago my idle has dipped from 710 to about 610-600 while the car is in Drive. I've tweeked the idle screw on the IACV and all it seems to do is raise the base idle i.e. when the car is in neutral. I've disconnected the brown throttle position sensor while adjusting the idle but my car just does not want to idle higher then 610.
My car has 85k miles on it and in the past 6 months or so I have:
Cleaned the Throttle body
Replaced Fuel Filter
New Coils
New NGK's
The thing that worries me is my idle has dipped so low that its stalled twice now. What do you guys think might be the prob?
Old Aug 20, 2004 | 09:53 AM
XeroX's Avatar
Hella internets
vacum leak? check that.. replace some hoses.... clean your TB. just some things to check out...
Old Aug 20, 2004 | 02:29 PM
jaykid806's Avatar
what? my car does the same thing, i think it might be fuel injectors, but thats my opinion. i ran fuel injector cleaner and checked all my hoses, might be 02 sensors.
Old Aug 20, 2004 | 02:39 PM
gto400no1's Avatar
its not o2 sensors. my car does the same thing even tho i just replaced all 3 o2 sensors.
Old Aug 20, 2004 | 04:53 PM
njmaxseltd's Avatar
Warm the engine up to operating temp.
Turn off the engine.
Disconnect the TPS.
Start the engine and adjust the idle speed using the stop screw on the throttle body to 650 RPM's.
Reconnect the TPS and restart the engine.
If the IACV is working correctly your idle should be correct. If it's a bit low, try adjusting the screw on the IACV bypass to get your idle speed to ~700 in neutral with no load. (no load means no lights or A/C)
Old Aug 20, 2004 | 08:07 PM
jaykid806's Avatar
tonite im down the ave go to accel and car barely goes and shudders no cel light whats happenin? went from idling crappy to accel crappy.
Old Aug 20, 2004 | 08:15 PM
ThurzNite's Avatar
can you redline it? have you read the ecu codes yet?
Jae
Old Aug 20, 2004 | 09:25 PM
Xugg's Avatar
When my car was stalling the accel would studder for a sec then drive normally but recenlty its just been idleing very low, no ecu codes. Redlines fine. Ceared the 0505 code, I'm hoping maybe something will register.
Old Aug 20, 2004 | 10:02 PM
Maximus_95's Avatar
oh you know what, it might be your evap. control vaulve. i just got it fixed for having the same symptoms. my car would stall at neutral at times. get it checked out. i paid 6 bills for fixing that and getting 3 o2 sensors replaced. good luck!
Old Aug 21, 2004 | 04:48 PM
ThurzNite's Avatar
So after the 3 o2 sensors were changed, the mechanic took a guess and tried the ebay control valve? I wonder what made him think that? It's one of the last things I woulda checked... which I may hafta cuz I'm getting some random problems w/my car and the usual suspects are ruled out already. Thanx for the tip!
Jae
egali045
Aug 16, 2015 01:19 PM
doobadoo
Aug 15, 2015 06:43 PM
kirkhilles
Aug 8, 2015 10:53 AM
RealityCheck
Aug 5, 2015 06:18 AM
yat70458
Aug 3, 2015 01:16 PM
