Denso Iridium Power Spark Plugs VS NGK Platinum
http://www.customenterprise.com/view.../vts/design004
how are they VS out stock spark plugs in performance i'm planning to get my plugs change so i need your guys opinion
There is no need to use any other type of spark plug then OEM unless you are either supercharged, turbocharged or using nitrous. The factory ignition system is more then adaquite for stock cylinder pressures. You are not going to see any HP improvements by flip flopping between spark plug brands. However your vehicle may feel stronger simply because there is a new set of plugs installed. i hope that helps you with your decision.
JoshG
51
Sep 21, 2015 10:41 PM
sdotcarter
Sep 2, 2015 09:53 PM
