ES bushing creeping out of the bracket
Old Aug 23, 2004 | 06:38 AM
mzmtg's Avatar
Minister of Silly Walks
I installed Energy Suspension front anti-roll bar bushings a few thousand miles ago. I just noticed one of the center bushings is coming out from under the mounting bracket.
Anyone want to guess whether this means I have the bracket on too tight or too loose?
Old Aug 23, 2004 | 06:46 AM
KMax2988's Avatar
Mine did the same. Put the stockers back in and they still seem to do it a lil as well. Might just be the way the cookie crumbles
Old Aug 23, 2004 | 06:47 AM
VeeQueue's Avatar
Maxima.org Sponsor and Donating Maxima.org Member
Are the bushing slits facing towards or rear the car? (I dont have the manual in front of me and it was long ago since I installed mine but I believe its suppose to face the front).
Did you lube the bushings before installing them?
Also, when you installed the bushings did you jack the suspension up (via lower control arm/knuckle) while the car was on stands to simulate static ride height before tightening the bushing brackets?
Old Aug 23, 2004 | 06:58 AM
mzmtg's Avatar
Slits face the front
Yes
No, I didn't do that...
Old Aug 23, 2004 | 09:23 AM
VeeQueue's Avatar
So youre saying the bushings are forcing itself out of the bracket -- the lips on the side of the bushings that keeps the bushings centered beneath the brackets are physically going underneath the bracket itself???
The only thing I can think of is the tigthening procedure and the lube. If improperly lubed /wrong lube the constant twisting may force it out. The lube between the sway bar and bushing can be squeezed out and cause more friction. I remember that the diameter of the bushing ID was a bit smaller than the swaybar itself so I had to force the bracket on. However before I installed it I used a blade and put several slits on the ID of the bushings so the lube can go in the slits instead of being sqeezed out of the bushing.
Also try tightening the bracket w/ the suspension raised.
I will take a look at my bushings when I get home.
Old Aug 23, 2004 | 09:39 AM
mzmtg's Avatar
Yup, that's what's going on.
I'll score the inside of the bushing when I reinstall it to try and hold some lube. I'll also look up the torque spec for the bracket instead of just going for "pretty tight."
Apr 16, 2020 05:15 AM
knight_yyz
Nov 1, 2015 01:34 PM
Calabar
Oct 5, 2015 09:57 PM
JakeOfAllTrades
Oct 5, 2015 10:40 AM
