My A/C only works on high speed (4)- HELP!!
Old Aug 28, 2004 | 10:20 PM
aphillips4u's Avatar
Have anyone had this problem before ? My A/C only works on high speed. I looked in the Owners manual and it says for Speed(s) 1-2-3 its on one circuit and 4 is on another circuit and there should be a fuse for 1-2-3 but I can't locate that fuse box. Am I on the right track?
Plese Help.
Old Aug 28, 2004 | 10:54 PM
matty's Avatar
its a switch thats behind the glove box..its a cheap part but wait for someone to chime in that actually changed it before...
free bump
Old Aug 29, 2004 | 04:38 AM
Rick James's Avatar
Page 2 in the FAQ's
There is a resistor assembly mounted on the air duct close to the blower motor. That part has failed. It is used to control fan speeds 1, 2, and 3. Speed 4 is the maximum blower motor speed, so no resistors are involved. Replacing the resistor assembly is something the home mechanic can do. The only tool needed is a Phillips screwdriver. The replacement part costs about US$25.
The blower motor is located just above the passenger's feet. Look at the wires leading away from the blower motor. Just inches away from the blower motor there is an electrical connector located on the air duct. That's the resistor assembly. It is easy to remove and replace.
Replacement is the usual remedy. However, if a spot of localized damage is seen it may be repaired with a soldering gun.
There is a good photo of the blower motor and resistor assembly in the Haynes repair manual, page 3-8. If you don't already have a copy of this book, please get one. It will be money well spent.
a) Move the front pass seat all the way back (for convenience)
b) Remove a harness connector (with 4 wires I think) running into the bottom of the blower motor.
c) Remove the 2 philips screws that hold the blower motor resistor in place.
d) Put new one in, reverse install.
Blower Motor Resistor Part Number: 27150-1E405
You can get it here:
http://www.nissanparts.cc/cart/?pn=27150-1E405
Should be $28 at your local dealer. It's $28 delivered from discount Nissan parts sites.
Old Aug 29, 2004 | 06:50 PM
Wills98MaxSE's Avatar
1 of few unmodded 4G Maxs
http://forums.maxima.org/showpost.ph...2&postcount=32
Old Aug 30, 2004 | 04:59 PM
Thank you guys for the info I'll try it and let you know how I make out.
Old Sep 7, 2004 | 10:17 PM
epmax95's Avatar
it worked for me and it was easy!!!! about $45
vingodine
45
May 21, 2016 12:46 PM
dr3am
25
Oct 22, 2015 08:53 PM
jerrod99_se-l
Aug 27, 2015 08:27 PM
MaximaDrvr
Aug 19, 2015 08:20 PM
kenc15
Aug 5, 2015 08:29 AM
