changing oil
Old Aug 31, 2004 | 10:39 AM
Stos95's Avatar
changing oil
is it counter clockwise or clockwise to take the nut off to drain the oil
Old Aug 31, 2004 | 10:41 AM
mzmtg's Avatar
Minister of Silly Walks
righty-tighty, lefty-loosey
Old Aug 31, 2004 | 10:42 AM
stang233's Avatar
True
True True True
Old Aug 31, 2004 | 10:46 AM
deezo's Avatar
Hmmmm......
Sprint's Avatar
just keep turning that b!tch.. one way or another something will come loose
Old Aug 31, 2004 | 10:47 AM
zachosz's Avatar
Ok, since we're on this subject......
For the life of me I can't check my oil level, my dipstick is f***ed up. If i read the dipstick 5 times i'll get 5 different answers. The car is on level ground and has been sitting a while before i check it. What gives????
Old Aug 31, 2004 | 10:49 AM
RichP23's Avatar
Do you clean it off before you put it back in?
Old Aug 31, 2004 | 10:52 AM
Sprint's Avatar
ok time for me to head back to OT
Old Aug 31, 2004 | 10:55 AM
BlackCat's Avatar
RIP '98 Maxima SE
Easy squeezy lemon peezy!
LOL! I like that righty-tighty ditty!
Old Aug 31, 2004 | 10:57 AM
zachosz's Avatar
Of course, every time. My dipstick is kind of crooked, could that be it? Because I read from way empty to way full, it really ticks me off!!!
Old Aug 31, 2004 | 10:58 AM
Bluebird's Avatar
I am Roid Rage
Make sure you use an impact wrench
Old Aug 31, 2004 | 10:59 AM
Sprint's Avatar
ok this is too much for me
"my dip stick is crooked"
"did you wipe it off before you put it back in?"
ok time to wash the mind out of the gutter
Old Aug 31, 2004 | 11:16 AM
Jeff92se's Avatar
I'm needing a caw
Wow. This is probably the only time I'd recommend Jiffy Lube.
Old Aug 31, 2004 | 11:36 AM
RichP23's Avatar
Just make sure you don't start draining the oil first & then drive it there.
Old Aug 31, 2004 | 11:39 AM
MAXRB8's Avatar
I don't know about you but after I drain my oil I need a nap!
Old Aug 31, 2004 | 11:40 AM
Sprint's Avatar
please refreain from high activity you might pop a blood vessel
Old Aug 31, 2004 | 11:43 AM
Mr. Maxima's Avatar
hahahaha...
Old Aug 31, 2004 | 11:53 AM
spirilis's Avatar
rofl good god
Old Aug 31, 2004 | 12:01 PM
Audtatious's Avatar
Bandwagon Lover
If you can't get the nut off, I have heard of others pulling the oil filter and running the motor for a few seconds or more to get all the oil out of the engine.....
Old Aug 31, 2004 | 12:51 PM
zachosz's Avatar
I like what you guys are smoking............... can i have some????
Old Aug 31, 2004 | 12:53 PM
Sprint's Avatar
with a combination of your sig and your bent dipstick.. i don't think you need to be smoking anything
zachosz's Avatar
hehe I like my new sig BTW.... Thanks phenryiv1!!!
Old Aug 31, 2004 | 01:07 PM
|Bijan|'s Avatar
UCF Lexus
omfg.........
Old Aug 31, 2004 | 01:48 PM
PLUMMAXSE's Avatar
Who let you get under your car?
Old Aug 31, 2004 | 02:03 PM
mchne's Avatar
1234567890
Old Aug 31, 2004 | 02:18 PM
tomservo291's Avatar
drive to a shop that has air tools (such as a jiffy lube) and ask politely for them to quickly losen the bolt then hand tighten so you can do it yourself.
on all the cars Ive started doing oil on, they had previously done by shops with air tools and sometimes ive even needed to improvise breaker bars from pipe to losen the bolt; I've had one so tight I couldnt believe they didnt twist the head of the bolt off from overtightening..
Old Aug 31, 2004 | 02:51 PM
Brudaddy's Avatar
"How come I get different readings?"
1. you must wipe the dipstick off
2. you must check a few times
3. you must try not to bump the sides of the dipstick sheath
This could be caused from oil getting up into that passage way. It is nothing uncommon, but just something that happens. It will especially happen (obviously) right after the car has been running, as all the oil is hotter and moving around everywhere. Just let it sit and keep checking. Eventually, you will get two readings that are the same.
**NOTE: I would suggest to check your oil after the car has been sitting for a while.....maybe even overnite. That way, you should not have to do it so many times to get an accurate reading.**
Old Aug 31, 2004 | 05:29 PM
Triple8Sol's Avatar
I miss the .org!
Good question
Old Aug 31, 2004 | 06:06 PM
† ErV †
You people are cruel
Old Aug 31, 2004 | 06:25 PM
Digital's Avatar
VIP
Just bring it to a shop.
Old Sep 1, 2004 | 10:25 AM
phenryiv1's Avatar
Mod her. Ate her.
HAAAaaarrrrrrr! I'm a Pirate!
Old Sep 1, 2004 | 10:56 AM
Digital's Avatar
VIP
Software Pirate what?
Old Sep 1, 2004 | 10:59 AM
Jeff92se's Avatar
I'm needing a caw
I think it's humorous that you fling the "owned" smilie out when you got by the "built VQ" thread.
Old Sep 1, 2004 | 11:27 AM
Digital's Avatar
VIP
LOL hey man it was an honest question, some mechanic out there might have something built up. I have no idea. I learned. And I put the owned similie out there cause software pirates own companies hence the fact people dont have to pay for the software. It was not related to the thread @ all.
Old Sep 1, 2004 | 11:29 AM
phenryiv1's Avatar
Mod her. Ate her.
What are you talking about? Its an inside joke.
Old Sep 1, 2004 | 11:32 AM
mzmtg's Avatar
It's not that inside...
Old Sep 1, 2004 | 11:34 AM
phenryiv1's Avatar
Mod her. Ate her.
True, but most OT people know it...enough people know it that I would not expect a left-field comment like that. Blatant post-whoring!!!
5 month ban for DIGITAL!!!
Old Sep 1, 2004 | 01:49 PM
twiggy144's Avatar
Is this thread a joke?
Old Sep 1, 2004 | 02:34 PM
PLUMMAXSE's Avatar
OT
I once knew a guy that thought you only checked your oil when the oil light came on.
Needless to say by that time he needed a new engine!!
Old Sep 1, 2004 | 02:58 PM
96pearlmax's Avatar
Dont strip the threads...then you will be dumping oil everywhere
