Car stalling and hesitation at high speed
Old Sep 1, 2004 | 06:26 PM
MaxChaos's Avatar
I have a 95 automatic, which has been given me nothing but trouble for the past few months. Now the car stalls when I stop for a stop sign or get stuck in traffic. It seems to be doing that less frequently when I have the AC not running. In addition, the car hesitates or “jerks” at high speeds. I pulled off two codes for a Knock and Mass Air Flow sensors. My question is: can a faulty Knock and MAFS sensors cause the problems I described above? Please help.
Andre
Old Sep 2, 2004 | 03:31 AM
OneToughMax's Avatar
yes. read the faq's.
Old Sep 2, 2004 | 04:32 AM
qnpark8282's Avatar
bad knock sensor could cause the bad performance but not stalling. also even if u disconnect the maf the car will still run. just wont rev pass 3k i believe. check ur maf voltage. read the faq about how to check the maf if its bad.
Old Sep 2, 2004 | 08:55 AM
Pappa Grande's Avatar
This is a long shot, but I once has similar syptoms and it turned out that I needed a new muffler...good luck.
Old Sep 2, 2004 | 08:58 AM
NmexMAX's Avatar
dot dot dot ...
It's the MAF, I ahd the same probs recently. Sucks ha? If you ever get stranded, just unplug the MAF, and you can make it home, can't go over 2.5k though.
Old Sep 2, 2004 | 09:40 AM
kenju4u's Avatar
Empy fuel tank can cause similar problems too
Old Sep 2, 2004 | 10:57 AM
MaxChaos's Avatar
Thanks guys. Will change the MAFS and see what happens.
Old Sep 2, 2004 | 11:00 AM
lilaclucymaxima's Avatar
Team Ramrod
same exact thing happened to me, i havent fixed it yet, i just let my car warm up for 10 minutes and it runs fine... the only reason i havent fixed it is cuz im on vacation right now.
Lakersallday24
Jun 16, 2019 01:35 AM
Finkle
Sep 27, 2015 09:53 PM
MaximaDrvr
Aug 19, 2015 08:20 PM
acw
Aug 7, 2015 04:20 PM
