98...ECU P0450, and P1446...starting problem
Old Sep 6, 2004 | 01:12 PM
lxk's Avatar
lxk
The engine will start normally most of the time, but occasionally refuses to start (4-5 times in a row). The engine turns over normally, but no fire. The only codes stored are P0450 and P1446, both dealing with the Evap. system. I don't think this would cause the starting problem, will it?? If not, what is causing the starting problem? Thanks in advance.
Old Sep 6, 2004 | 03:22 PM
speedemn's Avatar
Just a shot in the dark here - but how old are your plugs? How many times do you let it turn over before you quit cranking?
Other idea - fuel pump.
Sorry, I have not had this happen but I am curious as to what it might be.
Old Sep 8, 2004 | 08:07 PM
lxk's Avatar
lxk
The plugs are originals...60k miles....You can crank the car for ten seconds or longer and it will not fire when it is having problems. Then randomly it will start immediately and run fine...so I don't think it is the plugs.
Old Sep 10, 2004 | 09:15 PM
lxk's Avatar
lxk
bump...bump...bump
litch
123
Jan 4, 2024 07:01 PM
jmlee44
Oct 2, 2022 02:13 PM
user 11122324
42
Jul 18, 2022 03:35 PM
gavin68
Sep 18, 2021 12:36 PM
HerpDerp1919
Sep 29, 2015 02:02 PM
