GXE limited slip?
Old Sep 9, 2004 | 07:36 PM
Phatbashar's Avatar
GXE limited slip?
So yesterday i was on my way to get two new front tires, so i decided to have some fun ......while burning out it felt as if it had limited slip, but i thought the gxe's didn't come with it, so i disregarded it, but then i looked in my rear view mirror and low and behold there are two long tire tracks behind me...i do another two burn outs and all have two tire tracks...i have a 99 gxe(manual) i have only heard of se's with limited slip but i guess i got lucky.....
Old Sep 9, 2004 | 07:43 PM
Terran's Avatar
I believe non LS can still leave two tire marks.
Old Sep 9, 2004 | 07:44 PM
Broaner's Avatar
2060lbs and falling...
Shall I help clear the air? 1. SE's do not have LSD. 2. Your car does not have LSD. Nissan has built a good enough open diff that will lay rubber when your on even traction and level surface. The point of an LSD is not to lay two rubber lines(Though it may be cool). LSD is beloved in the racing world because it gives the driver the ability to lay power much sooner after the apex of the turn. With an open diff it is impossible to effectively lay power anywhere before the exit without wasting valuable rubber, gas and speed. On the track, an open diff makes a lot of smoke and very slow times.
Old Sep 9, 2004 | 07:49 PM
JClaw's Avatar
Not if you have slicks...
Old Sep 9, 2004 | 08:01 PM
Terran's Avatar
I think he meant auto-x (not too many turn apex's on the 1/4 ).
Old Sep 9, 2004 | 08:06 PM
Broaner's Avatar
Actually, I was visualizing roadcourses but auto-xing has the same issue. D@mn newbie.
Old Sep 9, 2004 | 08:10 PM
JClaw's Avatar
No need to be a jerk about it.
Old Sep 10, 2004 | 02:59 PM
Phatbashar's Avatar
actually when the car is on jacks, when i move one wheel the other wheel also moves but in the opposite direction, so i DO have limited slip.....
Old Sep 10, 2004 | 03:01 PM
Jeff92se's Avatar
I'm needing a caw
No You Don't.
Old Sep 10, 2004 | 03:09 PM
XeroX's Avatar
Hella internets
lol...I dont think thats gives it justice....
I, along with MANY people will disagree that you have the LSD. Check your vin... thats the tru way of telling isnt it?
Old Sep 10, 2004 | 03:24 PM
Mark97SE's Avatar
You just defined an open differential! They need to both turn in same direction for it to be a LSD.
Old Sep 10, 2004 | 05:05 PM
MAXDADDY98's Avatar
Maxima.Org Bishes
Check Trans Axle# on VIN plate underneath the hood if you C the letter V in the list of letters then you have LSD if not U Don't but Maxima's Don't have LSD not sure of the 2004s
Old Sep 10, 2004 | 06:00 PM
BEJAY1's Avatar
Conecarver
I'm confused. My VIN tag is an "A" and not a "V". When I jack it up and spin one front the other spins the opposite direction. My car is an SE. I do have slicks. And I autocross. But I don't float. Does that mean I'm a duck or a witch?
Old Sep 12, 2004 | 09:10 PM
Broaner's Avatar
Your right JClaw, there is no need to be mean to him because he's is more ignorant than you. You on the other hand pretend to know everything and clearly know much less than the squirrel that got my tread on his forehead yesterday. And you know I'm not talking about just this thread right?
BTW, slicks can spin too. Why don't we compare auto-x times of Maxima's w/ LSD Street tires vs. open diff slicks. Fact is that your still gonna be spinning that single wheel even in stock power range w/ the slicks and the other car will beat you by an debateable margin. So, I don't retract my statement. D@mn newbie!
Old Sep 13, 2004 | 06:57 AM
Pimpmobile's Avatar
no USDM 4thgens have an LSD stock.
yes I have one stock but im CDM (canadian domestic market muhahaaha)
tarun900
19
Dec 20, 2021 06:57 PM
jerrod99_se-l
Sep 25, 2015 03:02 AM
Socalstillen
Sep 20, 2015 11:46 PM
JoelP
Sep 19, 2015 01:08 PM
