Which ignition wires to splice into for positive and negative?
I need to power a switch inside the car which I will put next to the cruise control. What are the wires on the steering column that I could splice for positive and negative.
Thank you!
Thank you!
This for 95-98 only:
12 VOLTS CONSTANT WHITE/VIOLET @ IGNITION SWITCH HARNESS
IGNITION 1 BLACK/RED @ IGNITION SWITCH HARNESS
IGNITION 2 RED/YELLOW @ IGNITION SWITCH HARNESS
Loosten a bolt under there thats grounded and slip in a wire of your own, then retighten.
I am wiring yellow front markers which I want to come on whenever I turn keys in ON position. I am putting a switch in between to shut them off if I will also. I thought to get power from cigarette lighter, but ignition wires are physically much closer to the button.
Will appreciate any input!
jmlee44
Oct 2, 2022 02:13 PM
AaronL
Aug 8, 2020 10:31 AM
DC_Juggernaut
Sep 28, 2015 04:07 PM
