Anyone ever use or have stock Lexus rims?
Old Sep 12, 2004 | 08:14 PM
Max96Se's Avatar
Anyone ever use or have stock Lexus rims on thier Maxima?
Maybe something like this:
http://cgi.ebay.com/ebaymotors/ws/eB...sPageName=WDVW
I've seen alot of sets go for pretty good prices, and I thought they wouldnt look bad.
Old Sep 12, 2004 | 10:26 PM
Nismotic's Avatar
Always sunny in philly
i believe the offset is different, so it won't fit.
i thought of getting IS rims as well...but they dont fit
Old Sep 13, 2004 | 12:18 AM
96pearlmax's Avatar
Different offset...agree w/ NISMOTIC
Old Sep 13, 2004 | 12:19 AM
Max96Se's Avatar
But IS300,GS300/400,LS400 & RX300 are all 5x114.3 arent they?
btw, I think some will "flame" us for tryna get non-nissan/infiniti OEM rims... but I think some of the Lexus rims would be nice if they fit, plus if you needed a good rim/tire pakage for winter or something... you know
Old Sep 13, 2004 | 10:39 AM
mendon99's Avatar
tastey wheat
no bolt pattern is correct... http://www.discountedwheelwarehouse...._Reference.cfm
Old Sep 13, 2004 | 10:44 AM
southeast_first's Avatar
i'm not sure if they fit... but they look sick. my friend's got a set in chrome on his sc300... gorgeous.
Old Sep 14, 2004 | 10:05 AM
Nismotic's Avatar
bolt pattern is correct, but offset is different.
If u dont believe me, then buy the rims.
Old Sep 14, 2004 | 10:07 AM
Jeff92se's Avatar
I'm needing a caw
Offset is not the problem. It's the hub bore and stud hole size that's the problem.
Old Sep 14, 2004 | 05:01 PM
Max96Se's Avatar
Ok, so they difinately would NOT fit? Everyone agree? Cuz some really good good.
Old Sep 14, 2004 | 05:02 PM
Max96Se's Avatar
OKay, well I am a little confused.... When looking for rims, do you have to match BOTH bolt pattern and Offset? And how do you get if the "stud hole" is the right size?
Old Sep 14, 2004 | 07:37 PM
z32drifter's Avatar
hub may be diff....... but the size of the studs is the same for Nissan and Toyota .. both are 12mm... pitch is diff..1.25 nissan and 1.50 toyota.... I know Acura hubs are smaller... 64mm to our 66mm hub .... I don't know the Toyota hub size
Old Sep 14, 2004 | 08:12 PM
nismos14's Avatar
§è~® f®ÈÄk
i've seen them on someones 4th gen i know it for sure (the is300 rims) so its definately possible... spacers *MAY* be needed and maybe a hubcentric ring or even hubcentric bolts
Old Sep 15, 2004 | 12:34 PM
Jeff92se's Avatar
I'm needing a caw
They will not directly bolt on. You need the hub bore increased to 66.1mm and the stud hole size might not be correct. Also there might be rubbing problems if you run anything bigger than the skinnny stock tires. For all the hassle, it's not worth it IMHO. I'd run Ford mustangs rims before Lexus rims. Obviously of course.
aw11power
Oct 10, 2021 04:57 AM
Apr 16, 2020 05:15 AM
coolsun
Wheels/Tires
Nov 13, 2016 05:01 PM
Fbana41
Aug 29, 2016 12:18 PM
jaydot901
Sep 29, 2015 01:18 PM
