spring clips for brake pads?
Old Sep 13, 2004 | 10:28 AM
ChrisA's Avatar
i changed my front brake pads and rotors and am now getting a constant slight scrape noise as the wheel turns. i don't think this one is the dust shield.
my camry has spring clips that keep constant pressure on the pads to push them away from the rotor when not the brake pedal is not pushed down. my maxima did not have these but should it? there are the little holes in the top of the pads for them to clip into.
Old Sep 13, 2004 | 01:30 PM
Chunger's Avatar
My other car is a Hybrid
If you "just" changed them, the sound may go away after some driving.
Most aftermarket pads don't even come with those holes for the spring clips... usually not a problem. I'd be more concerned about a sticking piston.
Old Sep 13, 2004 | 02:01 PM
98maximer's Avatar
yea i had the holes to and my old pads had those clips so i just took those off and put them on the new ones..
Old Sep 13, 2004 | 07:26 PM
ChrisA's Avatar
I'm worried about a sticking piston too I think. I did apply some grease to them at the time. I didn't think it was too much. Is there any way to test it to know?
Old Sep 14, 2004 | 09:42 AM
Chunger's Avatar
I'm not sure WHERE you added the GREASE unless you are referring to the 12mm sliding pins/bolts... You should have used some antisqueal stuff between the shim and pad backs, only.
If you calipers are starting to freeze your rotors will be very hot after a drive... On my old Supra, it was glowing red... it's pretty obvious and you can compare to the other side of the car. If the noise is "symmetrical" on both sides of the car... just wait a few days to see if it goes away unless actual braking performance is affected.
Apr 16, 2020 05:15 AM
NmexMAX
May 23, 2016 07:38 PM
leatherneck
Sep 30, 2015 09:16 PM
HerpDerp1919
Sep 29, 2015 02:02 PM
Socalstillen
Sep 26, 2015 12:01 PM
