what is a AAC valve?
Old Sep 13, 2004 | 05:17 PM
jaykid806's Avatar
my mechanic said that my AAc valve is reading low numbers. what does it do and wear is it located? thanks for the help- he says this is why my car is sputtering and rough idle hopefully!!!
Old Sep 13, 2004 | 05:26 PM
tynant's Avatar
I think you mean IAC - the idle air control valve.....cost like 3.50 and very easy to install....dont let him rip you off! It takes like literally 1 minute to install once you find it....
Old Sep 13, 2004 | 05:31 PM
jaykid806's Avatar
do you know where its located?
Old Sep 13, 2004 | 05:44 PM
tynant's Avatar
I forget....near the front exhaust manifold, underneath somewhere its hard to see...I am sure someone will chime in with a pic....Ive seen one in another thread but alas no search....
Old Sep 13, 2004 | 05:51 PM
jaykid806's Avatar
thanx ill go look for it, do you know symptoms of a this part acting up?
Old Sep 13, 2004 | 05:53 PM
Jatan's Avatar
It does NOT cost $3.50 (I'm sure it's more than that...) Look at the upper intake manifold pic here: http://forums.maxima.org/showthread.php?t=335886 you see the pink, purple, and brown connectors? That's the IACV. Disconnect the connectors (just like in that pic) and then take out the 3 screws and clean out it out with some throttle body cleaner.
There is some info in the How To thread at the top also. Here some info/pics I have saved from before for my personal record: http://www.jatan.net/IACV.doc (right click and save target as...)
Old Sep 13, 2004 | 05:56 PM
tynant's Avatar
mine was 3.50...its a little plastic tube! Got it from autozone....my mechanic installed it for free while I was getting other stuff done.
Old Sep 13, 2004 | 05:59 PM
Jatan's Avatar
You're probably talking about the PCV valve...
Old Sep 13, 2004 | 06:02 PM
tynant's Avatar
**** man I think your right...sorry!
TKHanson
Nov 24, 2018 01:39 AM
tseng1023
Oct 15, 2015 08:30 AM
hayne
Oct 5, 2015 11:53 AM
maxima297
Sep 24, 2015 08:57 PM
Pauley
Sep 23, 2015 08:40 PM
