HELP PLZZZ Car starts then shuts off!
Old Sep 14, 2004 | 05:06 PM
2 Da Max's Avatar
ok my car was driving normally all day and since i got it, now all of a sudden the car starts and shuts off, the rpm just drops! or it ildles low then shuts off. this happen only when i had a vacume leak a few months ago when i put on my short ram intake but i had that fixed and it idled perfect. the thing is i had that ilde speed code on for awhile then i got the ks code. i fixed both(ks changed saturday] and today after driving i was like u know what let me clear the code, and when i start the car **** cuts off on me. plz i need help i have no idea whats wrong. i hear a ticking noise by the TB when the car idles, and when i rev the engine it sounds like water drownig. NO I HAVENT DROVE MY CAR IN WATER OR GOT IT WET. i changed my fuel filter and spark plugs about 3 weeks ago, last week i changed my knock sensor.around my TB is clean wtf should i do? this car amazes me one day it works fine the next day some **** fawks up. im tired a fixin dis pos. neways i need help
Old Sep 14, 2004 | 05:57 PM
2 Da Max's Avatar
Bump My Car Has 73k On It
Old Sep 14, 2004 | 06:06 PM
Ralph Wigum's Avatar
damn, i dunno what to tell u.
Old Sep 14, 2004 | 06:44 PM
2 Da Max's Avatar
dam i need help wheres the idle screw
Old Sep 14, 2004 | 07:07 PM
2 Da Max's Avatar
if i cant find help here i cant find it nowhere else
Old Sep 14, 2004 | 08:12 PM
michaelnyden's Avatar
does the car die out after you just start up the car and the revs jump then it dies out? does it stay on if you give it some gas immediately when you start it up?
I only ask cause I had this problem a little while back and it turned out to be my engine coolant temp sensor which was cheap and easy to replace!!! mine wasn't pulling a code, but it did fit the nissan FSM as a possible cause to hard starting or staying alive....so I took my multimeter to it and sure enough, the sensor was out of spec...
Old Sep 14, 2004 | 09:25 PM
vortechpower's Avatar
your idle speed adjuster is located right by the throttle , its a small screw with an 8mm bolt. losen the bolt and turn to the right for higher rpm. check all conections like the mass air sensor and little things like that.
Old Sep 15, 2004 | 09:41 AM
2 Da Max's Avatar
yes thats what happens so this could be the problem?
Old Sep 15, 2004 | 10:09 AM
Pappa Grande's Avatar
two guesses: Engine coolant temp. sensor. Or have you messed around with your ECU lately? On my 95 the screw on the ECU does not stop turning. If I do not set it correctly when clearring any CEL's, the car will not idle correctly and will shut down....
Old Sep 15, 2004 | 12:22 PM
achi913's Avatar
I Have A Similar Problem, I Already Change My Coolant Temp Sensor Twice, And My Car Still Shuts Off And Can't Accelerate.
Old Sep 15, 2004 | 01:46 PM
2 Da Max's Avatar
Yo I Did Mess With The Ecu To Clear The Codes, Is It ****ed Up What Do I Have To Do?
Old Sep 15, 2004 | 01:51 PM
just try turning the screw a little bit. Then start the car. If that doesn't work, turn the screw a bit the other way and start the car. You can easily rule this possibility out.
Old Sep 15, 2004 | 04:44 PM
2 Da Max's Avatar
Thanx Guys It Works !!!!!!!!!!!!!!!!!!!!!!!!
Old Sep 15, 2004 | 06:36 PM
MAXecutive's Avatar
check your MAF, i had lots of stalls because of my fcuked up harness, wires are kinda loose on it.
Lakersallday24
Jun 16, 2019 01:35 AM
MaximaDrvr
Aug 19, 2015 08:20 PM
Stagnet04
Aug 16, 2015 11:15 PM
Trin1j23
Aug 12, 2015 08:31 PM
mrgooch
Aug 9, 2015 11:00 AM
