Strange hesitation in 4th and 5th ONLY...look inside
Old Sep 15, 2004 | 12:55 PM
phenryiv1's Avatar
Mod her. Ate her.
I noticed that i am getting a strange hesitation in 4th and 5th (5MT).
It happens when I am cruising along, and usually around 60 mph, though it has happened above that speek. RPM are around 3K (give or take a few) in 4th and a little lower in 5th. If I go to accellerate, I get a strange result:
First, I can hear the engine noise build. After this, the RPM slowly climb a few hundred, BUT THEN they fluctuate a few times, by a hundred or so RPM. The same thing seems to happen in 5th, but the RPM are a bit different. I am trying to isolate speeds and engine RPM, btu it ifs hard to do that while watching traffic. Also, the highways here are 55 mph, so I have to watch for cops while experimenting.
I have several KNOWN problems in my car, which may or may not be contributing:
1. POSSIBLE exhaust leak between the B-pipe and the muffler, due to no gasket there. It is also POSSIBLE that the piping has a small leak.
2. CEL from an EVAP canister and valve problem.
3. CEL for KS, BUT every source (even the dealership service department) says that it is just an after-effect of the EVAP codes.
Old Sep 15, 2004 | 08:49 PM
phenryiv1's Avatar
Mod her. Ate her.
Sorry- the hesitation is at 3000 rpm in 4th or 5th- not @ 60 mph in both gears.
Old Sep 15, 2004 | 09:39 PM
nick's Avatar
Mine hesitates too, (auto) at 38mph when transmission is in 4th gear (overdrive) , i step on the gas almost to the point of WOT, and nothing happens - no kickdown to 3rd - just slow build up of RPM's till 3500 -3800 than it moves but it feels so sluggish.
All the maintenance is up to speed, I have hacked air box . NO CODES ... Knock sensor has 15k on it.
I will try to clean the MAF sensor, and i will look at coolant temp sensor.
also the throttle position sensor is resonsible for providing ECU with inputs that relate to engine load and driver demand.
Nick.
Old Sep 15, 2004 | 10:08 PM
matty's Avatar
http://forums.maxima.org/showthread.php?t=323971
May be the same thing I am getting...people say it may be the MAF gettin old
-matt
Old Sep 16, 2004 | 05:16 AM
phenryiv1's Avatar
Mod her. Ate her.
matty-
I will read over the links in the link there, btu one note i that I have all stock tranny components. Also, I am at about 108-109K.
I could use a tranny fluid change...
Old Sep 23, 2004 | 08:32 PM
phenryiv1's Avatar
Mod her. Ate her.
Back to the top for another run through the hinterland...
Old Sep 23, 2004 | 09:00 PM
matty's Avatar
People are thinking its the MAF causing this ??
-matt
Old Sep 29, 2004 | 01:33 PM
mansurxk's Avatar
anyone shed some new light on this, i have the same EXACT problem, i twas really bad at first with a small intake, i replaced it with stock, helped a bit, then chagned my fuel filter and PCV valve, and it took about 80% of the problem away, but its ongoing
litch
123
Jan 4, 2024 07:01 PM
James92SE
142
Jan 2, 2024 09:23 AM
tarun900
19
Dec 20, 2021 06:57 PM
AaronL
Aug 8, 2020 10:31 AM
worldwiderecognized
Sep 24, 2015 06:56 PM
