need a quick about window switch HELP!!
Old Sep 19, 2004 | 12:48 AM
9maximuz8's Avatar
need a quick answer about window switch HELP!!
hi
i f*cked up my driver side window switchs and now nothin works on it but the lights AND one of the windows is half way down so if someone can tell me if the 95-99 switchs are all the same im goin to get one tomorrow??
thanx
oya and is there a fuse somewhere that i might have blown??
Old Sep 19, 2004 | 01:16 AM
99se5spd's Avatar
yea theres a fuse, look in the owners manual or the on the fuse panel cover where they are listed. might be under the hood too in the main fuse box. as for years...i think 97-99 are different?
Old Sep 19, 2004 | 01:40 AM
9maximuz8's Avatar
thanx i did look for the fuse under the hood and its fine
Old Sep 19, 2004 | 12:03 PM
9maximuz8's Avatar
bump..............
Old Sep 19, 2004 | 12:45 PM
99se5spd's Avatar
what did you do to mess it up? there is a circuit breaker too, but that resets automatically, unless something is still shorted.
Old Sep 19, 2004 | 06:00 PM
9maximuz8's Avatar
i was changing the LEDs in it and now the LEDs light up but nothing else work
where is the circuit breaker??
Old Sep 19, 2004 | 08:49 PM
99se5spd's Avatar
i have no idea where it is, but it is automatic. it might be in the main fuse box under the hood. make sure the legs of the leds arent too long and touching something, visially inspect everything in the switch looke for burn marks and stuff. you might just have to get another switch man.
Old Sep 20, 2004 | 12:58 AM
9maximuz8's Avatar
ya i think i have to get a new switch soon if it starts raining in ****ed
thanx for the help tho
Old Sep 20, 2004 | 06:49 AM
MaXaZoR's Avatar
I have the same problem with both my rear windows and power locks. Somehow either your main controller is broken or the wires got pinched. The only way to fix is to sit there w/ a tester and check each wire looking for where the connection got broken. If all the wires are fine then its your main controller. Good luck
Old Sep 20, 2004 | 09:47 AM
wariow's Avatar
so the lights work except the windows?? or neither works?
Old Sep 20, 2004 | 10:22 AM
9maximuz8's Avatar
the lights work but nothing else does
Old Sep 20, 2004 | 07:21 PM
TJ_Max's Avatar
Paradox Systems Vendor
Yea I Got Problems With This Myself, My Rear Windows Wont Go Up And Down Wit The Driver's Side Control Panel, And I Tried My Rear Windo Switches And My Lights Dont Go Up And Down Anymore....i Need Some Help Myself
Fbana41
Aug 29, 2016 12:18 PM
jsmith24
Feb 1, 2016 12:35 AM
lrb6805
Sep 24, 2015 05:03 PM
keensali
Sep 23, 2015 08:59 PM
