shock sensor install question
Old Sep 21, 2004 | 07:06 PM
YellowOne's Avatar
for those who have done this mod, just wondering what brand of shock sensor you used. also which location did you use. thanks
Old Sep 21, 2004 | 07:16 PM
RA030726's Avatar
I'm nutty for Nissans
get a brand name one, such as DEI. put it inside, maybe on the steering columb. im going to do this very soon.
Old Sep 21, 2004 | 07:49 PM
aznprid972's Avatar
i got a really cheap one from a guy on ebay. probably no brand but it works the same. on where i placed it... i had it on the BCM at first so now it is zipped tied to the metal frame inside the center councel. if you take out your whole center councel.. you'll see the two metal frame that goes up and down on both sides inside. i just zip tied it to the left one. doesn't really matter what side but it gave me a better sensitive spot. if i hit my front tires with my palm hard enough.. it'll set it off.
also.. for those who have done this mod... can you press your "lock" button again once your alarm has been activated (after 30 seconds or when the security light starts blinking) ? for some reason.. if i lock my car and press lock again once the alarm is set, the alarm goes off. but i can keep pressing lock as many times before it is set.
Old Sep 21, 2004 | 07:53 PM
YellowOne's Avatar
aznprid972, do you by chance still have a link or possibly a pic of your sensor, also which way do you mount it, thru the bcm?
Old Sep 21, 2004 | 07:56 PM
aznprid972's Avatar
oop.. just edited my post.
Old Sep 21, 2004 | 08:02 PM
aznprid972's Avatar
mine looks like this one
http://cgi.ebay.com/ws/eBayISAPI.dll...721071986&rd=1
Old Sep 21, 2004 | 08:06 PM
YellowOne's Avatar
aznprid972, sorry but do you have directions, seems like your sensor had 4 wires, curious of how you hooked yours up and where you hooked it up.
Old Sep 21, 2004 | 08:55 PM
aznprid972's Avatar
it should be just only 3 wires. positive, negative, and the signal wire.
heres the link i used to installed:
http://www.vqpower.com/v2/modules.ph...howpage&pid=13
hope that helps!
Old Sep 21, 2004 | 09:01 PM
bearded's Avatar
Yeah I got that same shock sensor that aznprid972 did by his recommendation. Installation is a breeze and it works great.
But yeah I noticed that too aznprid... sometimes I go outside cause I thought that I forgot to lock my car and I press the lock button.... the alarm goes off and it takes a while to turn it off. Oh well, not a big deal. I think maybe the clicking of the bcm shakes the sensor enough to trip it or something.
Old Sep 21, 2004 | 10:31 PM
aznprid972's Avatar
i thought i was the only one and messed up installing it. glad to hear im not alone.
rbuswell
Nov 12, 2016 04:11 PM
homeyclaus
Sep 3, 2015 06:15 PM
MAXSE5SPD
Aug 23, 2015 12:06 PM
doobadoo
Aug 15, 2015 06:43 PM
Greenmaxspeed
Aug 8, 2015 12:39 PM
