mevi installtaion helpp please
Old Sep 22, 2004 | 06:11 PM
Max97Stick
mevi is installed theres a wire goin from the ecu to the rpm switch then goes groun n pos to the battery know there was a wire from coil 1 goin to ?? i had somebody install it and it go ripped of from shiftin know mevi doesnt work can anybody help me where the wiere from coil 1 goes to and i can fix thanks
Old Sep 22, 2004 | 06:17 PM
I30tMikeD's Avatar
What RPM switch are you using? You only need to tap of either the ECU or the coil pack for the rpm signal. Not both
Old Sep 22, 2004 | 06:53 PM
Max97Stick
so how would i know if i mevi is workin
Old Sep 22, 2004 | 07:12 PM
I30tMikeD's Avatar
If your not going to anwser the question I can't help you.
Old Sep 23, 2004 | 06:48 AM
Max97Stick
im not sure i got it from somebody they installed it
um ill try n get pics today n send em to u
Old Sep 23, 2004 | 07:09 AM
NmexMAX's Avatar
dot dot dot ...
Whenever doing any work on your car, even if you dont inslall items yourself, make sure you know and understand the way everything is linked togehter and how it works so if there are any problems, you dont have to take it to whoever installed it all the time for simple troubleshooting like you're having now. And its pretty sad to see that you dont even know how to tell if its working, not the slightest clue from what it seems like. Not trying to lecture, just trying to give advice. Most of us here on the org do our own homework and really get involved even it its just understanding a concept, such as the VI.
Old Sep 23, 2004 | 07:24 AM
I30tMikeD's Avatar
It's gonna be real hard to explain things or help if you did not do the install and don't know how it is supposed to be. Without doing it yourself your not gonna be able to anwser any questions.
You may need to find a max owner in your area with a VI to help you.
Old Sep 23, 2004 | 07:55 AM
NmexMAX's Avatar
dot dot dot ...
Why dont you contact the seller and ask what switch they had?
litch
123
Jan 4, 2024 07:01 PM
maxprivate
Nov 29, 2017 08:52 AM
maxprivate
Forced Induction
21
Jul 8, 2017 09:48 AM
BkGreen97
Apr 2, 2016 05:47 AM
lrb6805
Sep 30, 2015 08:12 AM
