need some adivce my temp
Old Sep 24, 2004 | 05:06 PM
Max97Stick
sometimes when i turn my ac my temps goes to hot duno what it can be
Old Sep 24, 2004 | 05:24 PM
maximus_pr's Avatar
fan not turning on
Old Sep 24, 2004 | 05:30 PM
Mr. Maxima's Avatar
how long does it take ur fan to tuen on after the temp goes off? does the temp go down very quickly when the fan kicks on?
Old Sep 24, 2004 | 06:30 PM
Max97Stick
fan works it doesnt pass halfwya till i drive on with the ac maybe i need new theromstats or switch duno how u check
Old Sep 24, 2004 | 07:23 PM
nissanguy8's Avatar
that just happened to me, after changing the water pump, both hoses, the thermostat, I took out the radiator and had it rodded out, well the guy at the radiator told me that he could not stick the rods in the radiator because it was so clogged, so I bought a brand new steel radiator for $150 out the door and problem was finally solved!!!!!
I really think its your radiator, I went through the same thing, temp would be consistent until I turned on the AC, then the guage goes to like 3/4's !!! Scared the hell out of me!!!! My fans worked normally too. I stuck a meter to measure the temps and I had cold spots in the radiator, thats an indication of something clogged.
Old Sep 24, 2004 | 07:35 PM
Max97Stick
ok so ima go to nissan and diagnosis my car for 80 dollars n tell me to check my radiator n stuff
Old Sep 24, 2004 | 07:59 PM
nissanguy8's Avatar
I would take your radiator out yourself,(its very easy) take it to a local radiator shop and see if they can rod it out forusually about $75 or so, if they can, your problem is solved, if they can't, you will need a new radiator. get a steel radiator, usually sells for about $135 I got mine for $150 out the door.
Miket2006
Mar 1, 2021 03:55 AM
Apr 16, 2020 05:15 AM
fastcarny
Oct 6, 2015 10:42 AM
msellas
Sep 23, 2015 09:16 PM
NissanNismoZ
Sep 12, 2015 07:30 AM
