Passenger door light wont turn off? why?
Old Sep 25, 2004 | 11:56 AM
bigx323's Avatar
Passenger side door light wont turn off? why?
My passenger door light wont turn off when i close the doors, the driver side one turns off when its suppose to and works normally but the passenger side one just does not and just stays dimm.
There's constant power flowing to it, and its not as light as always , now its just dimm.
what could be the problem?
how would i fix this?
Old Sep 25, 2004 | 12:28 PM
bigx323's Avatar
bump
has anyone had this happen to them?
Old Sep 25, 2004 | 12:32 PM
MDeezy's Avatar
strange, not sure how to fix but I would disconnect your battery to save it from dying.
Old Sep 25, 2004 | 01:51 PM
bigx323's Avatar
i just disconected that hole assembly from its harness for that reason , but what distributes the power to that light bulb, like what regulates when its on/off as the doors open/close?
Old Sep 25, 2004 | 04:27 PM
bigx323's Avatar
bump!!!!!!!!!!!!!!!!!!!!1111
Old Sep 25, 2004 | 05:28 PM
ThurzNite's Avatar
My doors have a delay to them. They turn off after a while on their own.
Jae
Old Sep 25, 2004 | 07:19 PM
bigx323's Avatar
yea, but it my case it doesnt, it just became varry dim and just stays on, plus its a matter of only the passenger side one, the driver side door light turns off and works fine
Old Sep 25, 2004 | 09:52 PM
bigx323's Avatar
bumpty..........
Old Sep 25, 2004 | 10:13 PM
Guttermouf5150's Avatar
mine wont come on...
Old Sep 25, 2004 | 11:07 PM
bigx323's Avatar
can it be the passenger side window regulator?
or would this problem even trace to the front driver side window/lock control unit?
Old Sep 26, 2004 | 09:40 AM
bigx323's Avatar
ttt..........
Old Sep 26, 2004 | 09:52 AM
Batxel's Avatar
blah
x2
I replaced the bulb and it still doesn't light up is there a seperate fuse just for the door light. If so where is it?
Old Sep 26, 2004 | 11:14 AM
bigx323's Avatar
well mine just stays on...
Old Sep 26, 2004 | 12:00 PM
Maxtank's Avatar
The power for the door light is a constant. They are ground driven via the door switch, and run through the window switches. Thats all I really know. I had to run a ground from the drivers side to the passenger side to get mine working again.
Old Sep 26, 2004 | 12:18 PM
bigx323's Avatar
yea, i was jst about to do that very same thing, was just wondering if it was simpler to fix the problem from where it was arrising.
vingodine
45
May 21, 2016 12:46 PM
shaunkey1
Aug 18, 2015 10:09 PM
george__
Aug 18, 2015 07:06 PM
kjm900r
Aug 5, 2015 07:14 AM
Tanvirkamal
Aug 5, 2015 01:32 AM
