Ok, new problem
Old Sep 28, 2004 | 01:02 PM
Sassy Girl's Avatar
Ok, new problem
You guys were getting goofy on the last thread-so, I had to start a new one.
Ok, the car won't start cause there was no coolant in the radiator. So, we put coolant and water in there. Should I try to start it or get it towed to the nearest car shop???? I cannot even believe this!!
Old Sep 28, 2004 | 01:05 PM
PTownMax's Avatar
I still miss the max
is there a pool of radiator fluid on the ground?
Old Sep 28, 2004 | 01:17 PM
Sassy Girl's Avatar
Yeah, probably a 9" diameter spot. I thought it was the oil-but it is the radiator fluid.
Old Sep 28, 2004 | 01:18 PM
PTownMax's Avatar
can you see where the leak is coming from?
Old Sep 28, 2004 | 02:39 PM
thekenone's Avatar
id coolant can be mistaken for oil then u prob need to flush after u fix the leak. if the block or heads are messed up (worst case scenario) i doubt starting it will do more damage.
litch
123
Jan 4, 2024 07:01 PM
jmlee44
Oct 2, 2022 02:13 PM
user 11122324
42
Jul 18, 2022 03:35 PM
gavin68
Sep 18, 2021 12:36 PM
HerpDerp1919
Sep 29, 2015 02:02 PM
