Rad. Hoses not "HARD"
On my 95 GXE Auto, even though my car is fully warmed up, and the temperature gauge is in the middle, and car seems to be running fine, and coolant level is ok...my radiator hoses are still kinda soft and pressable. Does that mean that water pump is messed up?? Is there any other way to check if the water pump is bad while its on the car??/
Thanks everyone in advance
Then how do I know if the water pump is bad. I thought that the water pump was suppose to circulate coolant throughout the system.
Are your guy's hoses hard when the car is warm???? I can press mine.
This is PERFECTLY NORMAL.
The Pressure in our hoses is not all that great.
You know the water pump is going when:
a) Coolant starts spilling out of the passenger side of your engine.
b) your car overheats.
c) your engine blows.
Funny thing is - 4 years on this board and I've never seen anyone lose a water pump. I'm sure it's happened, it's just obivously really rare.
Actually, I believe Ange was asking about the water pump a while back. I also know that one dealership in Madison replaced one on a 4th gen Maxima at 190k miles.
They charged close to $450 for the water pump at that time.
Is replacing the water pump doable for DIY? For me, replacing a timing chain tensioner is out of my league, but brakes and suspension are not.
Nope you would have to loosen the tension on the timing chain just to get the water pump out. After that you need to take out the water pump which is a pain in the rear! So nope, I would recomend you taking this one to a shop and have someone that knows what they are doing take care of this one. Since there is so little space as it is just to get to the pump itself you would have an extremely hard time.
-Chris
-Chris
Originally Posted by iansw
I'm sure it's happened, it's just obviously really rare.
HerpDerp1919
Sep 29, 2015 02:02 PM
