sequential way of bleeding brakes??
Old Oct 3, 2004 | 05:35 AM
qnpark8282's Avatar
which is a correct way of bleeding brakes. i heard 4th gens have a sequential order. also i check the stickies it only explains how to bleed with speed bleeder.
Old Oct 3, 2004 | 05:47 AM
njmaxseltd's Avatar
Doesn't really matter where you start.
If your flushing or replacing the fluid with new fluid try this method.
Start at the driver side front wheel. Pump till the master cylinder is about 3/4 down, then refill. Do that 3 times so your master cylinder will be flushed and full of nice clean fluid. That gives you a nice clean reserve to start with.
Next bleed the rest of the system till you get clean fluid from each caliper. Go right around the car, right front, right rear, left rear and if you feel like it just crack the left front one more time. Remember never to let the master cylinder run dry!
Old Oct 3, 2004 | 10:42 AM
SuperFishstick's Avatar
for abs brakes, you are soppoused to start from the wheel furthest from the master brake cylinder, and work your way towards it. I think...
Old Oct 3, 2004 | 03:05 PM
A32Matt's Avatar
you are correct sir...start from the furthest wheel away. don't really know why but that's what i've always been told.
Old Oct 3, 2004 | 05:37 PM
acj's Avatar
acj
Yes…start bleeding with the wheel furthest from the master cylinder. That’s how we always do it in the shop, and we’ve never had any problems.
I'm not sure if its just for ABS though..I've always done it with all vehicles.
Old Oct 3, 2004 | 07:45 PM
Broaner's Avatar
2060lbs and falling...
Do not just go in order. VQuick and I recently had a very large problem when changing pads due to bleeding order. Maxima's have a different order due to having two main lines. The primary goes to RR and FL while the secondary goes to LR and FR. THE CORRECT ORDER IS: RR, FL, LR, FR. If you don't do it that way you end up with mad amounts of air. At least he did.
Apr 16, 2020 05:15 AM
leatherneck
Sep 30, 2015 09:16 PM
HerpDerp1919
Sep 29, 2015 02:02 PM
Socalstillen
Sep 26, 2015 12:01 PM
