Front/Rear seat removal + heater install
Old Oct 4, 2004 | 05:02 PM
Nismotic's Avatar
Always sunny in philly
Ran a search and didnt get specifics. What will i need to remove the front and rear seats in my 4th gen? i just upgraded to black leather and want to know what i'll need to do
Also, i've heard that 4th gens are pre-wired for heated seats. If the leather seats im getting are heated, what do i need to do?
Old Oct 4, 2004 | 05:20 PM
Vaudeville Villain's Avatar
This link will help you with the rears ....
http://www.carstereohelp.com/stereor...Max96RSpkR.htm
Old Oct 4, 2004 | 05:59 PM
jdm71488's Avatar
the rears aren't hard at all... i was installing my full range speakers and my mom took the seats out for me pretty much! as for the fronts... idk...
Old Oct 4, 2004 | 06:13 PM
Powerman5115's Avatar
For the fronts when I took out my passanger seat, all I did was take out the 4 bolts. There is one on eash corner of the seat, on the floor. This was on a 96 SE. Backs are easy, not sure about the heating.
Mooney
Old Oct 4, 2004 | 06:54 PM
Ceasars Chariot's Avatar
Old Maxima Legend
front
14mm socket i think it is ( 4 bolts per seat ) , you will see the plugs underneath to undo and plugin if electric.
back
reach under the front of the bottom section of rear seat and pull tabs. should pull right on out of the car. can use a socket set or small phillips head screw driver on top portion of seat. look behind the armrest for screws and under each side on the bottom section for one screw on each side.
on my 97 seems like i only have 2, which are one on each bottom side. but on the 96 seems like there were some screws behind the armrest.
Old Oct 5, 2004 | 10:45 AM
Aidan2474's Avatar
I put in a heated seat kit from Leatherseats.com, I searched and found a few good sites with information, that was like two years ago... its not hard to do at all, probably took me a little more than half a day with no experience at all, that included seat removal from car, leather removed from seat, installing heating elements(seat and back), reupholstering the leather seat, installing seat back into car, and wiring the switch to my lighter. Kit came with everything needed, I only did my seat, (driver seat) I still have the kit for the passenger seat.
Old Oct 5, 2004 | 11:24 AM
Nismotic's Avatar
delco huh? which part?
i've read that the car is already equipped w/OEM fuse to hook directly to the seats, but not sure where/how to do so.
JRod28
Dec 29, 2023 09:56 PM
Matt93SE
May 24, 2019 02:58 PM
homeyclaus
Sep 3, 2015 06:15 PM
kirkhilles
Aug 8, 2015 10:53 AM
13Maximasv
Aug 7, 2015 10:56 AM
