Uneven tire wear.
Old Oct 5, 2004 | 11:33 AM
sharkulator's Avatar
Uneven tire wear.
Ok here goes. I have 18's on my max, not lowered yet. I am getting uneven tire wear even though I keep them properly inflated and do the rotation and balance thing. I am getting the uneven wear on the outsides only and it seems to be affecting the driver's side more than the passenger side, I am not a fat a$$ either! I was wondering if the camber plates on stillen.com would correct this, but $400 is alot. Does anybody else make them cheaper? Thanks for any help.
Old Oct 5, 2004 | 11:34 AM
PTownMax's Avatar
I still miss the max
obx makes ehm
Old Oct 5, 2004 | 11:37 AM
off hand do you remember the price?
Old Oct 5, 2004 | 11:54 AM
mzmtg's Avatar
Minister of Silly Walks
You probably have too much toe-in.
Get the alignment checked/fixed.
Old Oct 5, 2004 | 01:05 PM
BEJAY1's Avatar
Conecarver
Checking toe & camber at home
Yes either toe-in or possibly too much postive camber. Most shops will do an alignment check at no charge. I've started doing my own in my garage as I keep swapping parts..
Toe - park, and point both wheels as straight ahead as possible. Does the driver side point inward more than the other - there's the toe. To measure drop a plum line from front & rear of tires to the ground and measure between both sides. I usually get within 1/4".
Camber - if you've got a level and ruler you can compare L&R camber. Measure the from the center of the wheel to the top and compare the angle from true vertical. Maybe it's 4mm on one side and 7mm on the other. Get funky with trig functions and you can calc the angles.
Old Oct 5, 2004 | 04:02 PM
maximaman10's Avatar
Get an alignment.
Old Oct 5, 2004 | 06:58 PM
I did that and pretty much wasted $50.00 because all four wheels were aligned. I guess the main question here is will the camber plates help?
Old Oct 5, 2004 | 07:04 PM
Tek-Niq's Avatar
my rear view mirrors flap like a f-ing bird
What!!!!!! do not spend money on no camber plate brother just do as the people say, an aligment will solve your problem.
Old Oct 6, 2004 | 05:12 AM
BEJAY1's Avatar
Conecarver
Could you post your measurements then?
Old Oct 6, 2004 | 05:53 AM
mzmtg's Avatar
Actually, only the front wheels were adjusted because there's no way to adjust the rear wheels. FYI
Old Oct 6, 2004 | 02:51 PM
I will post them as soon as I get home still at work.
coolsun
Wheels/Tires
Nov 13, 2016 05:01 PM
Garrettz459
Sep 28, 2015 02:50 PM
