Help w/ CEL Evap Control System/ABS
Old Oct 5, 2004 | 01:39 PM
Saddles's Avatar
So my ECU is throwing 0111...
- EVAP control system does not operate properly.
- EVAP control system has a leak in the line between intake manifold and EVAP control system pressure sensor.
Possible causes include ...
- EVAP canister purge volume control solenoid valve stuck closed.
- EVAP control system pressure sensor and its circuit.
- Loose, disconnected, or improper connection of rubber tube.
- Blocked rubber tube.
- Blocked or bent rubber tube to MAP/BARO switch solenoid valve.
- Cracked EVAP canister.
- EVAP canister purge volume control solenoid valve.
- Closed Throttle Position Switch.
- Improper connection of one-way valve.
- Blocked purge port.
- EVAP canister vent control valve.
Anyone have pictures or explanations on where this stuff can be found so I can start checking it out? Instructions on how it should be so I can make sure everything is correct? Thanks a lot.
Also...my ABS light is on...however...my ABS is working correctly. What might be causing this? One of my friends said a fuse, which fuse?
Old Oct 6, 2004 | 09:53 PM
Saddles's Avatar
bueller...bueller...
jmlee44
Oct 2, 2022 02:13 PM
tarun900
19
Dec 20, 2021 06:57 PM
tseng1023
Oct 15, 2015 08:30 AM
RealityCheck
Oct 2, 2015 06:34 PM
DC_Juggernaut
Sep 28, 2015 04:07 PM
