which flywheel is better: Unordthodox or fidanza
Old Oct 7, 2004 | 10:13 PM
DEKMax's Avatar
I need feedback on these flywheels since I'll prolly be buying one of the two fairly soon and they arent cheap. Thanks for any input.
Marc
Old Oct 7, 2004 | 11:18 PM
liqidvenom's Avatar
brotherhood of tq
the lighter the better, i've never heard anything bad about the unorthadox flywheel
Old Oct 8, 2004 | 03:39 AM
jcy98maxse's Avatar
Turbo is too much fun!
I have fidanza and I like it, not too light not too heavy.
I've heard that there are problems like bogginess with the Unorthodox fly(being too light) but not 100% positive.
Old Oct 8, 2004 | 06:24 AM
nismomax98's Avatar
got fidenza just put it on and its great car runs smooth, no complaints so far
Old Oct 8, 2004 | 08:03 AM
Linkage23's Avatar
Good choice! Fidanza is the wayt o go if you want some drviability left in your max! I've already gone through two of them and wouldn't think of getting a different brand. Good show!
Old Oct 8, 2004 | 09:23 AM
MrEous's Avatar
^ Jeff™
You've already gone through 2 Fidanza flywheels? Did I read that right? How long did they last? How many miles on your Max?
Old Oct 8, 2004 | 09:27 AM
Jeff92se's Avatar
I'm needing a caw
I'd be carefull about saying "lighter is better". It is only to a point. I read a thread where after you mount all the stuff needed to make an unothordox unit work, it ends up being about the same weight as a Fidanza anyway. BlackbirdVQ or something mentions this.
Old Oct 8, 2004 | 12:06 PM
Linkage23's Avatar
Fidanza x2
Yeah you read right. On my first Fidanza I matched ut up with the ACT Stage II clutch and I basically resurfaced the flywheel while being used. I had to go back to the OEM clutch and Fidanze flywheel for driveability issues. Bar-none the best flywheel available for the Max, as far as aftermarket ones go. I was just a little excited with the clutch/flywheel combo that I burned them both out after only 10k miles. Since than I've had no troubles what-so-ever.
Old Oct 8, 2004 | 12:42 PM
liqidvenom's Avatar
brotherhood of tq
well i have yet to hear one bad post about the unorthadox flywheel. it seems people just assume its not good without having any proof.
Old Oct 8, 2004 | 01:04 PM
Flava_24/7's Avatar
Boosted Panda
I have the Stillen flywheel, which is the same as the UR flywheel. made by the same Co. just distributed by two different Co.
My flywheel weighed right at 7 lbs, You have to use the outer ringgear from the OEM unit.
With the flywheel complete. It only weighed like 9-10 lbs. Which is much lighter then OEM, but not sure what the Fidenza weighs.
Old Oct 8, 2004 | 01:08 PM
Jeff92se's Avatar
I'm needing a caw
Fidanza is right about 11.5 to low 12lbs.
Old Oct 8, 2004 | 01:15 PM
Stephen Max's Avatar
I just installed a Fidanza flywheel, and I weighed both the stock flywheel and the Fidanza. Stock came in at 17.3 lbs, Fidanza at 12.
Matt93SE
May 24, 2019 02:58 PM
KabirUTA13
19
Oct 17, 2015 02:15 AM
kenc15
Sep 25, 2015 06:38 AM
