Hard time removing starter
Old Oct 9, 2004 | 10:41 AM
amulla01's Avatar
I got the 1999 maxima se, and yesterday I got to the starter to fix the noise. First of all, I got 2 problems. I cant get the clip disconnection from the one that goes to the battery (the clip is really hard to get unlucked and its masked with tape or something)Is there a sensor on top one of these wires? thats what it looked like with tape all over it... I gave up on the clip and tried to remove the starter with the thin wire connected but now the starter wont come out... It's like it got cooked to the metal exterior and fused with it... any suggestions on how to safely remove the damn starter without damaging it?
Old Oct 9, 2004 | 11:12 AM
s0ber's Avatar
Uh what do you mean it got cooked, when I took off the 2 bolts that thing just fell off.
Old Oct 9, 2004 | 11:29 PM
amulla01's Avatar
the 2 bolts in the front that has the 2 wires connected to it right? Well I took them off but starter wont come off, i tried to push it around and it dont get separated from the metal casing... will not budge
Old Oct 9, 2004 | 11:46 PM
Maxine's Avatar
No, there are no wires attached to the bolts. Look farther down the shaft of the starter closest to the engine. Its like a 12mm and a 14mm if i remember right.
good luck
Old Oct 9, 2004 | 11:57 PM
bigx323's Avatar
u didnt take off the main starter bolts, sounds like u took off the bolts of the part of the small part of the starter on the side of the main starter block,, look further down to the bolts on the sides of the starter
Old Oct 9, 2004 | 11:58 PM
amulla01's Avatar
oh ok... man there's hardly room in there to fit the ranch
Old Oct 10, 2004 | 12:00 AM
Maxine's Avatar
Its alot easier if you remove your whole intake up to the tb.
Old Oct 10, 2004 | 08:49 AM
mansurxk's Avatar
yeah, you definatly need to take eveyrthing off up til the TB othwrise its not happening. like everyone else said, 2 bolts.
http://www.motorvate.ca/mvp.php/516
Old Oct 10, 2004 | 02:13 PM
amulla01's Avatar
The 2 bolts that are showing are the ones I removed. There is another bolts on the other side which seem to be hard to get at and a freaken battery wire tapped over the front 2 bolts...
Old Oct 10, 2004 | 02:14 PM
amulla01's Avatar
by the way its not my car, this car seems to have starter easily accessible... unlike mine with tons of **** on top of it with many various wires
vingodine
45
May 21, 2016 12:46 PM
MaximaRaj
27
Oct 2, 2015 07:31 AM
MaximaDrvr
Aug 19, 2015 08:20 PM
Samedi
Aug 13, 2015 04:05 PM
