Suspension advice needed (control arm installation)
Old Oct 12, 2004 | 04:55 PM
jim84's Avatar
My left front control arm needs to be replaced ('98 SE). It squeaks every time it hits even the smallest bumps in the road (sounds like I've got bluebirds trapped under the hood). All I have is a hydraulic jack to raise one side of the car. Can I replace the control arm without having to lift both front wheels at the same time?
Also, does anyone recommend against a beginner like me taking on this kind of challenge, or is this the kind of task I can accomplish if I'm good at following instructions?
Any other tips?
Thanks to all who respond,
Jimmy
Old Oct 12, 2004 | 05:22 PM
maxs4life's Avatar
i think that you better get both sides up man do its not that hard .
Old Oct 12, 2004 | 05:42 PM
njmaxseltd's Avatar
You need both sides up or your going to be fighting the sway bar for sure.
Old Oct 12, 2004 | 07:45 PM
jim84's Avatar
Thanks for your response. You're right; it seems easy enough. But what's the best way to get the whole front end up? My guess is two hydraulic jacks would be too unstable. I'd hate to get crushed by my own car just to save a couple hundred bucks.
Old Oct 13, 2004 | 07:25 AM
Gibby's Avatar
Use the jack to set the whole front end up on some jack stands. They should be pretty cheap, and you may be suprised how many times you'll end up using them.
smplyamzng
Dec 13, 2015 01:19 PM
TonyJr
Aug 20, 2015 12:14 AM
AT978
Aug 15, 2015 06:39 PM
soon2ownmax
Aug 13, 2015 02:19 PM
laparka66
Aug 6, 2015 09:36 AM
