what is causing max to smoke like this?
Old Oct 13, 2004 | 09:33 AM
chancy31's Avatar
here recently my car has started smoking every now and then. It is real weird only after I hit the brakes and when I'm backing up. It will smoke like you poured seafoam in it for about twenty seconds and if I let it idle it will stop after that, and even if I give it hell it doesn't smoke then. any ideas on what exactly is happening?
Old Oct 13, 2004 | 11:51 AM
PTownMax's Avatar
I still miss the max
smoke off the engine or smoke out the exaust?
Old Oct 13, 2004 | 12:00 PM
matty's Avatar
yea where is the smoke coming from ?? the breaks, engine, exhaust, black smoke, white smoke ??
-matt
Old Oct 13, 2004 | 12:40 PM
chancy31's Avatar
It is blue coming from the exhuast, I'm pretty sure that's oil so I don't know if their is a bad seal or something, if it were the rings i would thinkt that it would smoke all the time.
Old Oct 13, 2004 | 03:19 PM
MaximaSE96's Avatar
Maxima Owner
bad valve seals...it proil ly does it when u start it up cold too just keep checking your oil levels
Old Oct 13, 2004 | 03:22 PM
f550maranello2's Avatar
ouch that sucks man blue smoke is a bad sign, valve seals and piston rings! sorry to hear that.
Old Oct 13, 2004 | 03:43 PM
Ant96GLE's Avatar
Your burning oil, the only reason you see it when you stop or back up is because the exhaust is accumulating in your muffler system and is being let out.
Ever stop at a light and when it turns green the car in front spews out smoke and after a second or 2 it stops... thats the reason why.
I would start with checking your spark plugs to see if they have any oil residue on them, if they do its the valve seals, if not it could be bad piston rings or valves...
captchaos
Mar 15, 2016 12:18 PM
ballerchris510
Sep 10, 2015 09:35 PM
