Brake and Battery Lights Light came on Help???
Old Oct 18, 2004 | 05:25 AM
maxlauj95's Avatar
After i wash my car's engine, the brake and battery lights came on when i start the car on. I let it dry and start it again and driving for a while and it go off for like 30 minutes but then came back on. I think a ground wire is loose but i'm not sure which..... Any suggestion where the wires could be loose? or where should i looks for loose ground wires???
Old Oct 18, 2004 | 05:36 AM
Sprint's Avatar
check the battery terminals first.
You are on the right track, but without knowing whats going on with your car their is no accurate depiction of what the exact problem is.
Check the battery terminals to make sure they are not loose or corroded. Then get a volt meter and you can then move on to ground connections. If you don't have a volt meter .. a long wire and a bulb will do also.
Old Oct 18, 2004 | 05:52 AM
njmaxseltd's Avatar
Battery and brake light on means your alternator has stopped working.
Old Oct 18, 2004 | 06:21 AM
Sprint's Avatar
I have had my brake and battery lights come on and my altenator was working fine
Old Oct 18, 2004 | 07:00 AM
maxlauj95's Avatar
I think my is loose wires somewhere, but didn't find yet.....
Old Oct 18, 2004 | 08:54 AM
Flava_24/7's Avatar
Boosted Panda
I had my brake and Batt light on me, and I had heard it was my alt going out.
So I kept it in mind to replace it soon. I kept putting it off, since my car never lost power and it had been over 2 mo. since the lights first lit up.
Then one day it happened, I was in traffic on an upper deck when all lights got dim( night time) and my radio turned off.
and car eventually died.
Alt was DEAD and battery was drained.
Had to get pushed to an exit ramp and coast down to a parking lot and wait for a tow truck. Not fun.
Some say it could be the connector that plugs into the alt, It comes loose somtimes somehow. Check that first.
IF its not that, keep the failing Alternator in mind.
Old Oct 18, 2004 | 09:00 AM
maxlauj95's Avatar
Thanks, I'll kept that in mind FLAVOR247.....
Old Oct 18, 2004 | 10:39 AM
Wills98MaxSE's Avatar
1 of few unmodded 4G Maxs
bye bye alternator
Old Nov 6, 2004 | 05:46 PM
white95max's Avatar
I'm having this problem too. My Passport 8500 is showing 13.5V+ so my alternator is fine (I just replaced it about a year ago). My lights only come on for a few minutes at a time, or sometimes they just flash.
Old Nov 6, 2004 | 08:04 PM
maximaseefu's Avatar
when my brake and battery lights came on it was my freakin acc belt shredding off on the middle of the highway. I considered myself lucky to have not lost my idler pulley.
tsi6001
Oct 3, 2022 10:23 PM
homeyclaus
Sep 3, 2015 06:15 PM
Nismo_Guy89
Aug 24, 2015 09:49 PM
Samedi
Aug 13, 2015 04:05 PM
Superbform
Aug 11, 2015 08:10 PM
