Why Is IT So Hard To Find All 4 O2 Sensors For MY 99 Cali-Spec Maxima?!!?
Old Oct 18, 2004 | 07:49 AM
PharoNDmist's Avatar
My Check engine light came on and I used my OBD II scanner to pull the codes, come to find out that I have 2 bad o2 sensors. I'm burning gas like crazy,(probably getting 6miles to the gallon)so I'm going to replace all 4 with new sensors becuase I'm coming up on 70k miles.I looked almost everywhere online and they only have 3 of the 4 I need.I even went to www.oxygensensors.com and courtseynissan, they both only have 3 of the four. I sure as hell dont want to go to the dealer and get ripped off,but I have to do something about this problem soon. Can someone please help me out, I'm spending a fortune on gas a day.
Old Oct 18, 2004 | 08:01 AM
njmodi's Avatar
Do I get a tax break?
Did you check at www.jrnissanparts.com? If they don't have it, they can get it for you in a few days - but will still charge the discounted price.
Old Oct 18, 2004 | 08:41 AM
just called there and they don't have all 4
Old Oct 18, 2004 | 08:46 AM
SonicDust187's Avatar
Are you sure there are 4. I took a look on my friends 99 and he only has 3 o2 sensors upfront. Thats it.
Old Oct 18, 2004 | 08:55 AM
1MAX2NV's Avatar
There are four. Why do you need to find a place that stock all four? You can't wait few days until they order the missing one?
Old Oct 18, 2004 | 09:08 AM
Where is the 4th? I know there is one on the front catalitic and two more on the ypipe. So where is the 4th?
Old Oct 18, 2004 | 09:16 AM
1MAX2NV's Avatar
Front Exhaust manifold I think.
Old Oct 18, 2004 | 09:17 AM
I was just looking at the fsm and only see 3.
Old Oct 18, 2004 | 09:21 AM
1MAX2NV's Avatar
You have a FSM for 1999 Cali-spec?
Old Oct 18, 2004 | 09:29 AM
I have fsm for 95-99 and it has a diagram specific for cali emmision cars.
Old Oct 18, 2004 | 09:36 AM
ChinoX's Avatar
Bring it B*tch!
From: Queenz, nYc CarClub: NYCMAXIMAS.ORG Website: www.ChinoX.net
PharoNDmist, I have the same problem, what is the cheapest you're getting for 3 of them?
Old Oct 18, 2004 | 09:52 AM
njmaxseltd's Avatar
Only the front two o2's are used to adjust a/f and give you back your gas mileage.
The rear ones only monitor the pre cats. If there not bad, save your money they will not effect performance.
Old Oct 19, 2004 | 05:17 AM
mkothari's Avatar
California emission
I have 99 california emission car. IT has four O2 sensors.
Why do you want to replace all ? They are expensive.
I purchased one read bank2 ( I think). It cost me $146.xx including tax.
I was getting code P158/P159 which referes to rear sensor.
After replacement, engine light is gone. (By the way, the Nisaan Service Manual
says this particular sensor do not control engine at all). So my car was
running fine even though check engine light was on.
I am no expert in this but I am pissed off that this part go bad and cost so much money and I do not understand why some of us accept it as normal.
May be I am not as rich as others or I expect better products from manufacturers.
Old Oct 19, 2004 | 07:36 AM
1MAX2NV's Avatar
There are four for sure. I was under the car last night working on something else.
Old Oct 19, 2004 | 07:59 AM
ChinoX's Avatar
Bring it B*tch!
ok so where is the cheapest place to get them? How much?
Old Oct 19, 2004 | 08:21 AM
Can you please tell me where each one is? My friend has a 99 cali and I could only see 3. I couldnt find any extra o2 sensors after the cat.
Old Oct 19, 2004 | 08:47 AM
vipervadim's Avatar
I like Maximas
ok here we go:
ON 99-01 Calis:
1st: easily seen in the front header
2nd: after the huge front precat (below header with 1st O2)
3rd: screws into the y-pipe after the 2nd O2
4th: after rear header in y-pipe
there are NO O2 sensors after the y-pipe
Combine all those O2 sensors with the swirl valves in the lower intake manifold and all 99 calis are the slowest maximas
ON all 95-99 Fed cars there's one rear O2 (after cat) and 2 O2 in the y-pipe (one after front header, and one after rear header)
there are 3 sensors in the front and 1 in the rear which ones control a/f ration???
the 3rd sensor died on my cali after warpspeed y-pipe, and now my gas mileage is worse than a Range Rover.
Chino let me know if we can get a GD on it. or somewhere to get replacements on them.
I will check with jerryromenissan and see if we can get anything going with them or at least the 10% LIMaximas.com discount
Old Oct 19, 2004 | 12:24 PM
danbortz's Avatar
im having the same problem on my 99 Cali, i replaced my exhaust WS Y-Pipe and a Magnaflow muffler, now my CEL is on and throwing 4 codes...i dont remember what they are off the top of my head (im at work).
i thought i read somewhere that an exhaust leak in the system would throw all the codes, or is it definitely all 4 O2 sensors?
i'd be down for a group deal too, keep me posted.
Thanks guys!
Old Oct 19, 2004 | 10:31 PM
Thanks guys, Replacing the bad ones will cost me less if I don't need all of them. I'm getting codes p158 and p138, anyone know specifically what sensors those are? ChinoX, If All I have to replace is two sensors I'm going to get them from www.oxygensensors.com. To my knowledge, I belive they still have the maxima.org discount for 20% off of the full price. But as soon as someone can help me figure out those codes,I'll get them then after
Old Oct 20, 2004 | 06:19 AM
ChinoX's Avatar
Bring it B*tch!
Cool, just let me know when you order, I'm having 2nd thoughts of selling my baby and if I keep her, then I def. need to get this sensor, I'm getting 15mpg
Old Oct 20, 2004 | 08:31 AM
Anyone know the codes P158 and P138 from an obd II scanner. I tried looking up the codes but they come up undefined. Anyone???
Old Oct 20, 2004 | 10:30 AM
mkothari's Avatar
Codes
You can look up on internet or soemwhere on this forum.
Old Oct 20, 2004 | 10:33 AM
mkothari's Avatar
I found on searching web
P0138 O2 Sensor Circuit High Voltage (Bank 1 Sensor 2)
P0158 O2 Sensor Circuit High Voltage (Bank 2 Sensor 2)
Old Oct 20, 2004 | 10:18 PM
Thanks mkothari I really appreciate it
Old Oct 21, 2004 | 01:33 AM
NightRider's Avatar
Could it be that two of the O2 sensors share the same part no.?
Old Oct 30, 2004 | 11:36 AM
OK. I went and did some research. Found that the P138 and P158 codes have the part numbers for the o2 sensors to be 226A1-4L715 and 26A0-4L713. I'm not sure if its for the downstream sensors after the cat, but I went to http://www.oxygensensorwholesale.com...99_maxima.html where they have decent sensors, but I'm not sure which two apply to those part numbers. Would any body know if these sensors are compatible?
Old Oct 31, 2004 | 07:04 AM
bump.........
Old Oct 31, 2004 | 03:16 PM
123456789...10
Old Oct 31, 2004 | 06:54 PM
jaykid806's Avatar
can anyone explain somethin 4 me. i replace 2 front 02 sensors. my car has rough idle at stop lights but drives fine on highway or movin. gets bad mpg and no cel. dealer said its a wire harness problem or ecu is this true?
Old Nov 2, 2004 | 08:14 AM
A couple a months ago, I had a similar problem with the car idling rough and poor gas milage(Still poor gas milage to this day). I checked for codes and saw that it was the knock sensor. Repalced the Knock Sensor and 2weeks later I had a cyl 5 misfire, Replaced the coil and that still didn't help. Took it to Jeff at Maximum tuning and found the problem to be a broken wire from the ecu to cyl#5. So before you replace parts,it is very possible you might have a fualty wire from the ecu.99's have terrible coil packs and ecu problems
mrc00l88
Jan 25, 2024 01:14 PM
kjlouis
Nov 24, 2018 06:09 AM
Max Nu-BE
Aug 11, 2015 06:34 PM
Wolvee
Aug 11, 2015 12:24 PM
yat70458
Aug 3, 2015 01:16 PM
